need help with led convert on mirrors
Old Sep 1, 2013 | 08:47 PM
HRDBDY808's Avatar
HRDBDY808
Default need help with led convert on mirrors
. well i have an issue. my puddle lights are turning on. i check the voltage and it reads 12 volts however on the lock position ,it should read 12 volts on the unlock position. it there a switch or fuse for just that area. i did the credit card method and tried to shove it back it and i strip two wires however connected it back and shrink wrap it good. so idk what else to say . need help anyone had this experience.
Old Sep 1, 2013 | 10:55 PM
HiloDB1's Avatar
HiloDB1
If you stripped the wires they may have shorted out. On the door itself there is a control box that handles most of the door functions on of them being the mirror and the courtesy light. You may have damaged it.
Old Sep 2, 2013 | 03:39 AM
HRDBDY808's Avatar
HRDBDY808
The only thing could be wrong would be a fuse . Or something. Everything on door still works . N their is current flowing through . Jz not at the right time
Old Sep 2, 2013 | 06:19 PM
HiloDB1's Avatar
HiloDB1
There is no fuse for that. If it was a fuse the light wouldnt come on at all.
Old Sep 3, 2013 | 02:01 PM
HRDBDY808's Avatar
HRDBDY808
true thanks just found that out from a mechanic. im about to get a wiring diagram for it. maybe a diode in it . who knows i want this thing fix. ill check that control box.
imherenow
41
Oct 14, 2013 02:51 PM
dorkacho
Jan 10, 2012 11:48 PM
N1T3MARE
Maintenance
Jul 12, 2009 06:37 PM
rainman49
Oct 21, 2006 07:06 AM
