HOW TO: LS430 Mark Levinson EVERYTHING w/Pics & part#s
yeah +1 on tweeters. i blew mine listening to the Offspring. I will update after I do some research on the tweeters. I want to make sure they will match the power of the ML tweeters so the system will be properly balanced. i been super busy last couple of weeks so i havent had a chance to update this or to even touch my car other than repairing the sub
i figured one of those million cig lighters will be a constant 12v [confused]
Great write up. I have a question about the sub I want to remove my sub and ad my own sub with an amp just for it and no longer usE my ML sub which wires do I use as my input to my amp?
Amplifier Output Wire Colors (at Amplifier):
Left Front Tweeter Wire (+): Pink
Left Front Tweeter Wire (-): Violet
Right Front Tweeter Wire (+): Light Green
Right Front Tweeter Wire (-): Blue
Left Rear Mid Speaker Wire (+): Black
Left Rear Mid Speaker Wire (-): White
Right Rear Mid Speaker Wire (+): Red
Right Rear Mid Speaker Wire (-): White
*Left Rear Subwoofer Speaker Wire (+): Black/white
*Left Rear Subwoofer Speaker Wire (-): Yellow/Red
*Right Rear Subwoofer Speaker Wire (+): Red/White
*Right Rear Subwoofer Speaker Wire (-): White/Blue
P.S.
Updated:
1: tweeter section
2: wiring section
3: NAV DVD how/what
1. crosover- a) if the cross over takes away greater range you will be missing some frequecy levels which will make your car sound "odd" if you rearrly looking for proper sound. b) if the crossover does not remove enough lower frequency, you will blow them as soon as you turn up the stereo, same thing if you have no crossovers on them.
2. Impedance- If impedance is different, tweeters will be too quiet or too loud and throw off the whole balance of the stereo.
3. From what i read, i think you need to pull the dash out to get to one of the tweeters
