Lowered '01 UL Air Suspension I Made Shorter Rods
5 Attachment(s)
I couldn't find any pictures of cars with 20's with shortened rods in the different positions (normal and high switch) so I could see the difference so I figured I would lay it out and post it up for those of you wanting to do the same thing. For those of you looking to lower your UL Air with the rods, there are many threads out there with the info on how to do it.
The problem with sourcing threaded rod to use is the fact that one side is right hand thread and the other side is left hand thread. So I looked and looked for a company that had threaded rod with half right hand threads and half left hand threads that I could switch my height sensor rods out with so I could put it back to stock when I sell it. No Go! Can't find them, they don't exist in metric (at least I couldn't find them) The standard rods can't be purchased through Lexus without the sensor over $300 (yeah right!) and even at that they don't have enough threads I initially lowered it using the standard rods but they were too long and it wouldn't sit low enough and I didn't want to cut the rods, besides there aren't enough threads it seems to lower it enough. So I had to make some, I got the proper threaded rods and nuts I cut each side of the rod shorter than each half of the factory rods and welded them together. I put them on the car, dropped the rear height sensors all the way down and lowered it down in the front to get rid of the gap, I'll be getting the alignment taken care of next week. pics are the - Shorter Rods I made Car lowered on the Normal and High settings from the front corner Car lowered on the Normal and High settings from the side Front and rear wheels on Normal and High (next post if it lets me) This is about as low as I can go without scrubbing and standard lips and I'm not planning on rolling or cutting the lips/fenders either. The rims are Cheapie Sport Edition ST4's and they require centering rings from (Tire Rack) Size: 20x8.5 Offset: 42mm Backspacing: 6.45" Bolt Pattern: 5-114 Tire Size: 245/35-20 I redded out the Amber Tails with red vinyl The tint is VA Legal and I have the sunshades up It still rides smooth because of the air struts, the 20's though increased harshness a little bit, but that's fine, I usually drive in sport mode anyway. |
4 Attachment(s)
Front on Normal setting
Front on High setting Rear on Normal setting Rear on High setting |
very nice, the little extra drop looks good
Very cool.
So with the sensors adjusted, the factor air bags will deflate to a specific ride height dependent on what you set it to. So you will lose some amount of travel compared to say, lowering with an SS kit, correct? |
those look like amg wheels
Originally Posted by waijai
(Post 5560493)
Very cool.
So with the sensors adjusted, the factor air bags will deflate to a specific ride height dependent on what you set it to. So you will lose some amount of travel compared to say, lowering with an SS kit, correct? The way I look at it is this is essentially what the data contoller does but you can't adjust it on the fly with the exception of switching the switch to the high position which seems to raise the front and rear about an inch if you need to or want to. Someone else might be able to chime in with more info about the SS kit |
very nice!
love the way how it sits:thumbup: |
Any pics of the parts installed?
4 Attachment(s)
(Post 5560713)
They work great, plus I still have my original ones to put back on the car later. Also I might be able to make some for people that have already cut theirs if they need stock sized rods if you want to put it back to stock or near stock prior to sale. 2 more pics as well. |
I used the rod method back in the day when I first got my UL. I got pretty proficient at adjusting it as you just need to turn the front wheel full turn to adjust one side and then same for the other. Literally took only a minute to do. Lowering the back just took sliding on your back to get to the 10mm nut and slide it up or down. An excellent easy way to drop the car and make it look good.
To shorten the rod, I bought a die to make my own rod. Very hard to find but a specialty tool place should be able to get you one with the correct reverse thread pattern. Just went down to Lowes Hardware and got a 4 foot length of blank rod with the same diameter, cut to length, then use the die. I could of make a dozen with the blank rod that I got and should of and sold them to cheap to all the CL brothers here :) Only needed about 4" or so on each side. I finally just broke down and got the Datasystem Controller and never looked back. |
Does anyone have the thread spec available? I have access to a supplier that can do this for me for very cheap.
Airtime, you saying that with the DataSystems Controller there is no need for this? Or anyone else feel free to chime in...
I just think that doing this may result in more harm than good, with the integrity of the rod in question and all... just my input. I could probable have these made also if someone had the specs, I probably could make an SS Kit copy given those specs. I have a machine shop in my unit, lol... |
The data controller eliminates the need for this. I feel it won't cause too much harm as long as I don't get to crazy with the shortening of the rod. This just tricks the car to think it's riding higher where the data controller takes over full control and can dump the car all the way to the floor. I'd bet these rods are safer than the controller, but that's just my 2 cents.
Glen, That's a great offer are your rods straight because i'd imagine any bend would effect the accuracy. |
Originally Posted by LethalLS
(Post 7694894)
Thanks, Glen |
