Replaced o2 sensor - now mpg stinks!
Old May 13, 2010 | 02:39 PM
srqls430's Avatar
srqls430
Default Replaced o2 sensor - now mpg stinks!
A week ago, my CEL and VSC off lights came on and I pulled the code
and it said it was the bank 1 side 1 o2 sensor (thank you Club Lexus Forum!), so I replaced it with a Denso OE sensor 50 miles ago.
20 miles after I replaced it, I got a CEL p0134 error (no activity detected) and had it reset and it did not come back (yet), but now I get terrible mpg. I was getting 16+ around town - now only 13-14.
After installing the sensor - should I reset the ecu or something, or does it have to 'break in'? Is it possible I got a bad part?
Any suggestions would be appreciated, I don't want to burn up my cat by running too rich.
Thanks
Old May 13, 2010 | 05:45 PM
motohide's Avatar
motohide
The O2 sensor is a OEM Toyota or an aftermarket one? Sometimes the range of voltage given by the O2 sensors can vary and results in rich mixture (malfunction)...
Old May 14, 2010 | 07:00 AM
toantran99's Avatar
toantran99
Did you disconnect the battery and let it sit for a while?
Old May 14, 2010 | 07:45 AM
srqls430's Avatar
srqls430
Thanks for the replies.
I replaced it with a Denso, which from what I understand is the source for OEM Lexus sensors.
No, I didn't remove the battery cable. What would that do?
Old May 14, 2010 | 12:12 PM
srqls430's Avatar
srqls430
How does resetting the ECM resolve this? Isn't it 're-learning' now?
Also, what is the best way to reset it?
Old May 16, 2010 | 07:35 PM
motohide's Avatar
motohide
The computer should only take 10 minutes of driving or so before it has recomputed a correct map throughout the fuel curve and timing. These are not the old 8 bit computers on 80's Toyotas where things took long to adjust, these are complex fast calculating ECU's that perform things on the fly faster than we can diagnose by eye with tools.
If its taking longer than a full tank of gas for you to actually notice a decline in consumption economy, there is obviously something still very wrong. It may not be a crippling malfunction, but it will be worthwhile to visit a dealer or a specialist. These are complex matters of electronics and hundreds of sensors which might take an examination by a specialist to know from past defects on other cars and things prone on specific models.
I'm not trying to be unhelpful but sometimes a good eye by somebody who deals with these cars is all it takes to pinpoint a fault that's not recorded by the ECU and fix it.
MsbTTSupra
Feb 21, 2020 07:27 PM
lexisaurus
Apr 22, 2017 09:23 PM
Ldog22
Mar 1, 2017 09:13 AM
racerxxv
GX - 1st Gen (2003-2009)
Dec 29, 2013 08:23 PM
schan1w
Maintenance
Jul 29, 2010 11:09 AM
