02 LS430 laser cruise
Old Aug 24, 2009 | 05:08 PM
batman1's Avatar
batman1
Default 02 LS430 laser cruise
The outside sensor on my 2002 LS430 was damaged. Dealer advises the entire unit needs to be replaced at over $1,700. I don't use this feature and only want to use the normal cruise although this sensor shuts everything down. Any way to bypass the laser version so the regular cruise will work?
Old Aug 24, 2009 | 08:33 PM
LSin75075's Avatar
LSin75075
yeah. as soon as you tun the car on (or anytime while in park), press the outer button on the cruise lever to turn cruise control on (it will say "radar ready" on the dash) then press the cruise lever back and hold it back for about 3 seconds, it will switch the radar off and just say "cruise ready" or something like that.
you can't do it while the car is in motion because the second you enable cruise control, the radar will run a power on and through a "check cruise control system" warning.
Old Aug 25, 2009 | 07:42 AM
caddyowner's Avatar
caddyowner
This is good to know. On the Lincoln MKS, if the sensors are dirty or there is some other fault in the adaptive cruise control, there is no way to use "normal" cruise control.
propcop
Jul 10, 2015 10:26 AM
ejthomp
Nov 19, 2009 02:58 PM
rcf8000
Dec 18, 2006 09:03 AM
billnls430
Jul 13, 2004 06:00 PM
