LS430 x Mode Parfume
#62
I have the same wheels in 20x9 and 20x11. The wheel design is a big reason for the small lips. The face is actually concave so you have a thicker disc and lose some lip. I have high disc front and low disc rear and the lug holes are much deeper on the high disc.
BTW I love my wheels and your Mode kit is damn sick!
#65
1 Post
Ame, what size is your rears? 20x11 + what ?
#66
i would like to know a little about your ss kit. i am thinking about doing this in the near future. i am currently on stock wheels but have an 05 UL w/ controller. how much did you get the youzeland kit for, oh you said pro do you remember how much for the non pro kit? also is it true it doesn't mess with the suspension at all? what are the pros and cons of the SS kit?
#68
#69
thanks ^ ^, do you know if you can start out with the non pro kit and add the pro ball joints piece at a later date without having to re-purchase the whole kit? i'm on stock wheels right now and wouldn't really need the pro kit's extra wheel well space, especially not for the additional 350$ plus installation costs. are you 2 thumbs up on the ss kit yourself??
#70
The front ss pro kit and non pro is completely different. it's not just the ball joint but also the aluminum spacer that they supply, the block for the pro is wider plus the hole is shifted off center. i would recommend getting the pro kit over the regular one if you plan on going with aggressive wheel fitment or if you will be driving low. And yes i love the ss kit on the car
#72
so when its completely down its INSIDE the fender..
so then it would be tucking.. where does this flushness
come from? u can be flush or u can tuck.. you aren't making
much sense.. maybe im just not following where you are going with that...
