Gaskets, Oil drain plug and Differential
Old Feb 2, 2009 | 06:11 PM
Boldface's Avatar
Boldface
Default Gaskets, Oil drain plug and Differential
My first thread. Question: 2004 LS430
Would someone discribe the two gaskets... Are they plastic, aluminum or other. Are they the crush type? Are they replaced during each change?
Picked up and ivory colored plastic gasket from NAPA, I was told if was OE.
Next stop Toyota Dealer...
Old Feb 2, 2009 | 06:24 PM
molexGS400's Avatar
molexGS400
oil drain is a grey / black gasket
diff is a metalic crush type washer/gasket
Old Feb 3, 2009 | 06:05 AM
AlexusAnja's Avatar
AlexusAnja
Don't know about diff as I have not changed it yet. But the oil pan is solid, round type (not sure if you call these crush or not) but cheap enough ($.95 in bulk) to change every change.
Old Feb 3, 2009 | 11:37 AM
DNC's Avatar
DNC
Where do you get your washers and how many do you get for $.95? Thanks.
Old Feb 3, 2009 | 07:07 PM
AlexusAnja's Avatar
AlexusAnja
Default Dealership???
I have my current batch from the local Lexus dealer and I bought in "bulk" of 30 pieces. I just did a quick check on Irontoad.com and they have for ONLY $.80 EACH... so no need to even buy in large quantity.
Hey... always good to shop.
Old Feb 3, 2009 | 10:22 PM
DNC's Avatar
DNC
Thank you!
Old Feb 5, 2009 | 05:57 PM
Boldface's Avatar
Boldface
I'll pick them both up at the dealership... I'm just about all set for my first oil change. Thanks.
pauloil
Jun 21, 2013 08:09 PM
schmoozer
May 28, 2011 07:25 PM
pauloil
Feb 16, 2011 12:48 PM
jeff1941
Maintenance
May 15, 2008 07:03 PM
Grumpa72
RX - 1st Gen (1999-2003)
Jan 28, 2006 05:59 PM
