Replaced battery, but NAV screen, Master Key, Horn
Old May 20, 2008 | 06:49 AM
msrashida's Avatar
msrashida
Default Replaced battery, but NAV screen, Master Key, Horn
None of them work. Do I need to sell this car? Long story short, I left the headlights on all night on my 2004 LS430 because I switched them from the auto mode to the on mode inadvertently. The next morning, no start. I changed the battery and the car started right up except the Navigation screen is blank, the horn doesn't work, and the Master key is not detected. Do I need to let the car run or charge or click my heels three times?
Old May 20, 2008 | 06:49 PM
msrashida's Avatar
msrashida
Well Lexus figured out what was wrong.... (I assume everyone was stumped)
When attempting to jump the car, the popular roadside assistance service that I won't name, jumped it in reverse (posting the negative on the positive and vice versa). It blew out the main fuse. Lexus had to order the fuse, but it's a quick fix. They gave me a loaner car in the interim.
Old May 20, 2008 | 07:54 PM
mikevanle's Avatar
mikevanle
I was going to suggest a blown fuse too. I saw your post times:
Today, 09:49 AM
Today, 09:49 PM
I thought you posted it within seconds of each other. Then I realized they were 12 hours apart. Well glad you got it fixed. It shouldn't be a reason to want to sell the car. All is good when you are under warranty, almost.
Old May 21, 2008 | 10:01 AM
msrashida's Avatar
msrashida
Today, 09:49 AM
Today, 09:49 PM
Oh wow. I just realized my post times. I may need to play those numbers. Yes, it was a quick fix. Cost me $100 bucks. No warranty coverage for that.
Old May 21, 2008 | 12:36 PM
mikevanle's Avatar
mikevanle
Oh man, you got played by the Lexus hourly rate. You should have waited till at least a day. I normally don't check the forums till after work. Sorry to hear it costed so much :/ , but glad you got it fixed.
Old May 30, 2008 | 06:31 AM
papan's Avatar
papan
CL Folding 25,000
can some one tell which fuse i have to replace if my nvi screen is black and there is no light in the trunk. everything else seems to work fine.
thank you.
Old May 30, 2008 | 06:57 AM
GeorgeT's Avatar
GeorgeT
When I use the manual "lights on" in my '02 and forget to turn them off, they turn off when the car is shut off - the lights do not stay on and drain the battery.
Ugly19604
RX - 1st Gen (1999-2003)
Mar 30, 2018 05:38 AM
ohmyyikes
Maintenance
Mar 26, 2016 06:20 AM
neilvosko
Nov 5, 2015 08:33 PM
01ES300NYC
Feb 24, 2011 04:37 PM
mac187
GS - 1st Gen (1993-1997)
Nov 13, 2008 11:41 AM
