Plastic Skid Plate problems ?
Old May 8, 2008 | 05:03 PM
GregGH's Avatar
GregGH
Default Plastic Skid Plate problems ?
Hi
The plastic skid plate on 06 LS430 came loose and caused quite a racket while my wife was driving - finally having a local shop remove it.
So we get back to the area dealer and they initially said it is covered under warranty now they say it is not covered.
Has anyone else had problems with the plastic skid plate covering the bottom of the engine compartment??
Part of our problem is the car is a USA car and we are in Canada ... but... and we have a platinum extended warranty but the car is still under the initial 50,000 miles
Regards
Greg H
Old May 10, 2008 | 05:57 AM
GregGH's Avatar
GregGH
Bump ...
No one else has had their plastic skid plate come loose and scrape the ground ( you would know it from the noise ...:-)
Greg
Old May 10, 2008 | 06:47 AM
wanderer99's Avatar
wanderer99
You should have Zero problems with this car because the full factory warranty is still in place. The only way I could see this repair being denied is because it was caused by damage to the plate under the car, which is visible on the plate itself. If the plate just went loose by itself and had to be removed, it should be covered under warranty.
The USA car in Canada is not an issue. If the dealer mentions to you something about this being a USA car, or the dealer just doesn't want to really help you - go find another dealer. You'll eventually find a real Lexus dealer that wants to help you.
FUZCO
RC - 1st Gen (2015-present)
19
Aug 29, 2015 06:28 PM
jacksonman
Apr 10, 2015 12:06 PM
JRandy
Aug 8, 2014 07:06 PM
Lex Luthr
RX - 1st Gen (1999-2003)
Aug 9, 2006 10:02 PM
agreenbhm
Jan 28, 2006 03:15 PM
