0-20W oil or 5W-30 oil for 2005 LS 430?
Old 10-21-07, 09:42 AM
Paul B
Paul B's Avatar
Default 0-20W oil or 5W-30 oil for 2005 LS 430?
Somewhere I recall that Lexus changed oil specifications in 2007 and now recommends 0-20 weight oil and that the change was retroactive to 2004 and later Lexus LS models. Can anyone confirm this?
Old 10-22-07, 12:09 PM
CG lover
CG lover's Avatar
mine calls for 5 - 30 weight,, I use Mobil 1 in that weight ,,
Old 10-22-07, 07:05 PM
Stelth91
Stelth91's Avatar
Wouldn't really matter. Unless you live in a colder climate, for instance, Alaska, just stick with either 10-30 or 5-30.
Old 10-23-07, 07:54 PM
jaxrwld
jaxrwld's Avatar
stick with the 5/30! 0/20 is too thin. 0/20 is for the Ls460 in synthetic.
Old 10-25-07, 01:33 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
I've heard some info about Toyota changing the recommeded fluid, but not from any authentic source.
I'd stick with 5-30 until reaching 100K, then use 10-30. Then stick to 5-30 during the winter months.
If you live in a warm Climate where it never reaches 32F, and gets hot in the summer (florida) i'd stick with 10-30 year round.
Old 10-25-07, 01:34 PM
sonyman
sonyman's Avatar
Use what the manual calls for, so 5W-30.
Old 10-26-07, 02:55 PM
rjm
rjm's Avatar
My dealer uses 5w30 but it is "semi-synthentic"....or so the service writer said. Is there any problem in switching from standard oil to Mobil 1 synthentic?
Old 10-26-07, 06:27 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
non at all.
Old 11-02-07, 07:47 AM
awtrott
awtrott's Avatar
This is a full synthetic oil isn't it? Have you experienced any leaks or seeping?
Old 11-07-07, 06:42 PM
ancdmd
ancdmd's Avatar
Leaky seals with full synthetics are a thing of the past, back when these oils were still being perfected.
Old 11-08-07, 01:37 PM
awtrott
awtrott's Avatar
I currently use Mobil 7500, but will switch to the Mobil 1 5-30 this weekend. Thanks for your response.
Edgardo73
07-31-17 08:52 AM
LS400BOY
30
05-14-13 08:01 PM
mishutka
03-10-13 02:51 PM
Vpanin
12-09-10 08:12 PM
BAD RIDES
12-02-10 09:56 AM
Quick Reply: 0-20W oil or 5W-30 oil for 2005 LS 430?
