Change A/C Filter
Old Feb 6, 2006 | 01:48 PM
daryll40's Avatar
daryll40
Default Change A/C Filter
Well, last week I posted about what needs to be done at 30K Miles on my '04 LS. I am at 27K now. It appears that the A/C filter, however, isn't gonna make it. I am getting the red triangle and the "CHANGE A/C FILTER" message. Can this wait 3000 miles? And/or can I do it myself? I seem to recall that somewhere I read this was an easy do-it-yourself thing.
YAY STEELERS! I knew there was a good reason I remain here in Pittsburgh. One for the thumb!
Old Feb 6, 2006 | 03:05 PM
Tammy's Avatar
Tammy
May I recommend you review your owners manual on how to remove the filter. Remove it, vacuum and inspect it for tears or damage. They may be gently cleaned with a soft bursh if necessary and air dryed.. Reinstall and reset the indicator lamp, also in the manual.
Mine is in the glove box and is simple to get in and out with the aid of a flashlight. Replacements are reasonable with many online websites. It's also refered to as an "ACC" filter, A/C Cabin filter.
Old Feb 7, 2006 | 12:06 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Well, make sure you have the key in the ON position (engine not operating) and press the AC OFF button for a few seconds (i forgot if there was another button to press at the same time)... that should clear the warning.
Try it out.
Old Feb 10, 2006 | 07:10 AM
daryll40's Avatar
daryll40
Thanks guys! I vacuumed the filter with a shop vac yesterday and reinstalled it and reset the sensor. Seems fine now. When I go in for the 30K service in a few months I'll have it changed. It's good enough until then I believe.
riknchar
Jun 7, 2018 12:01 PM
agunjal
Mar 6, 2012 05:42 PM
Gtidan
Aug 18, 2009 12:01 AM
Fleainat
Jul 19, 2008 05:22 PM
lexusgabro
Oct 25, 2007 08:57 AM
