Misfire on #1
Old Mar 15, 2026 | 11:16 AM
ramirez32's Avatar
ramirez32
1st Gear
Default Misfire on #1
A while back I changed the spark plug seals as well as the valve cover gaskets on my ls430 while doing that I managed to pull the wires out on #1 cylinder injector plug that’s when the misfire first came up I changed out the plug with a universal one from Oreilly problem never went away I have tried a oem plug and redoing the connection I still have the same problem
the car has new plugs and coils and I have checked for spark so I know it’s a fuel problem so I took a listen to the injectors and #1 is not firing
I thought maybe a bad injector so I swapped it with the one next to it and the problem stayed on the #1 cylinder
I have not tested the wires leading to the plug yet but I’m thinking my problem would be there
One thing I noticed is that the ground wire from the other 3 cylinders is coming from the harness on the back or the motor and the one for cylinder #1 is coming from the front driver side of the car leading towards the ecu could that be my problem??
*I think it would be good to note that the car has been in an accident and the damage was right to the front of the car
Old Mar 15, 2026 | 11:26 AM
Quinten's Avatar
Quinten
Try adding a ground to the #1 injector
Old Mar 15, 2026 | 01:23 PM
alextv's Avatar
alextv
It happened when wires were pulled out so I would check the wiring and also make sure going to right pins.
Cole23
Jun 4, 2023 08:52 AM
epk1001
May 29, 2014 05:39 AM
Pocket Tre
RX - 1st Gen (1999-2003)
17
Oct 15, 2008 07:29 AM
mlevk
12
Nov 22, 2003 01:53 AM
