Power steeringggg pumP
Old Feb 17, 2026 | 01:53 AM
03blk430lxs's Avatar
03blk430lxs
4th Gear
Default Power steeringggg pumP
Im going to be replacing my power steering pump and my reservoir, but i cant seem to find a step by step or video guide, can anyone help me on how to do so? Also how do I flush fluid when pump is installed, and what power steering fluid spec and brand would have been in my car off the lot ?
Old Feb 17, 2026 | 08:46 AM
weldthedif's Avatar
weldthedif
i dont know of any how to guides, but it's not to difficult of a job. you will have to bleed air out of the system, you can do this by turning the steering wheel back and forth while the front tiers are off the ground, before you start it up for the 1st time with the new pump
Old Feb 17, 2026 | 10:40 AM
bradland's Avatar
bradland
The return hose attached to the reservoir, and the larger hose between the reservoir and pump, will be your biggest hurdles.
They will be stiff and contrary. They will likely get damaged during the process. Plan on replacing both, but keep in mind they are both metric, not inch size.
The res. to pump hose is rather expensive from Lexus, but you can buy a decent, correct ID, aftermarket hose from RA.
https://www.rockauto.com/en/moreinfo...t=7323&jsn=448
Daspyda
Sep 24, 2015 01:56 PM
acnup00tl
Jun 14, 2013 01:15 PM
worldforgo
Feb 4, 2012 09:47 PM
etex
18
Mar 26, 2009 12:55 PM
AVRsc4dub
Jul 16, 2002 05:29 PM
