Need Help - P0766 Shift Solenoid D performance/stuck off
Old Nov 30, 2025 | 09:30 PM
KeenanThePic's Avatar
KeenanThePic
4th Gear
Default Need Help - P0766 Shift Solenoid D performance/stuck off
I recently bought a 200k miles 05 ls340
and a couple days ago my transmission started to act up.
- engine light
- VSC light
- stuck at forth gear
1st mechanic [20+ years fixing Japanese cars] says to replace the transmission
2nd mechanic [ASE] (im taking it to him tomorrow)
3rd mechanic [AAMCO]
What do you suggest I do
When I Test drove the car b4 buying, the brakes were acting up when i was gently stepping on the brakes. Then it would jerk out of nowhere. Then go back to normal.
Seller then brought the car to his "mechanic" and changed the motor mounts and suspensions
Then when I started to drive it, after like an hour the code started to appear
Reading the forums, i found something that is related to the brakes. Could it just be a ECM issue?
Old Dec 1, 2025 | 05:17 AM
weldthedif's Avatar
weldthedif
have you ruled out the very common ECU repair issue ?
Old Dec 1, 2025 | 06:58 AM
KeenanThePic
4th Gear
I am not mechanically inclined. Do you suggest i take it to my dealership?
calebhwang
GS - 1st Gen (1993-1997)
Jan 2, 2024 04:49 PM
Rmatthews
Jul 2, 2021 12:53 PM
SeanGZZY
Apr 21, 2021 08:53 AM
Njtrucker
Apr 17, 2018 06:34 AM
