Looking for high-performance brake rotor recommendations
Old Jun 6, 2025 | 05:16 PM
ajhaley's Avatar
ajhaley
Default Looking for high-performance brake rotor recommendations
I’m after rotors that outperform OEM— on par or better in quality and better in heat mitigation -- at minimum slotted, ideally cryo-treated, and best-case scenario 2-piece and slotted. Not looking for budget options or overseas knockoffs. I’m trying to find the best front/rear setup available before stepping up to a full big brake kit. Thank you!
Old Jun 6, 2025 | 09:13 PM
05ls430518's Avatar
05ls430518
The 430 has massive 4 piston calipers in the front they more than sufficient for anything. The different rotors dont do anything a oem rotor is going to give you the best performance as it has the most surface area and is made from superior metals. The only other option is a $4000-$8000 BBK kit brembo makes a decent one.
Are you experiencing braking problems?
Old Jun 7, 2025 | 12:07 PM
ajhaley's Avatar
ajhaley
Thanks for the reply—I appreciate you taking the time to respond.
I’m familiar with the LS430’s factory braking setup and agree that the 4-piston calipers are strong. My goal isn’t to fix a braking issue but to find rotors that match or exceed OEM quality with improved thermal performance—something slotted, cryo-treated, or ideally 2-piece. I’m not quite ready to go full BBK, so I’m trying to identify the best high-quality bolt-on option before making that leap.
I’ve been trying to track down StopTech’s slotted rotors, which seemed like a solid middle-ground option, but it looks like availability has dropped off since they were acquired. If you—or anyone—has hands-on experience with a comparable or better alternative, I’d really appreciate the input.
Old Jun 7, 2025 | 08:49 PM
Thirteenthcor's Avatar
Thirteenthcor
Are you experiencing braking issues, brake fade? Has this vehicle been power-modded to the point where you need bigger brakes? Are you tracking it? Wider tires decrease braking distance; bigger brakes manage heat better to prevent brake fade. Bigger brakes don't equate to more stopping power. Slotted or drilled rotors remove mass, and therefore reduce a rotors ability to manage heat as well in smooth expansion curves, increasing the risk of rotor runout/warpage. Slotted removes surface area for brake pad contact; modern pads no longer offgass like back in the day so no need for gas mitigation; a center pad slot is all you need for dust expulsion.
Unless this car has been put under some FI+tune, wider tires, DOT4 or 5.1 fluid, and a quality OE replacement set of pads and rotors should do fine.
blanks81
Aug 23, 2014 05:55 PM
Stubagg
IS F (2008-2014)
15
Feb 7, 2014 04:57 AM
andygs300
Jan 26, 2012 12:21 AM
alphais300
Jun 18, 2010 10:03 AM
VP500
Dec 8, 2005 02:22 PM
