Front Rotors
Old Feb 13, 2025 | 05:35 AM
Spyder58's Avatar
Spyder58
4th Gear
Default Front Rotors
Looking for suggestions on front rotors...
I've bought OEM rotors, discount rotors, Mid range rotors. ALL of them shimmy.
Love my LS but i have to have smooth brakes!!
Old Feb 13, 2025 | 06:26 AM
Holden53's Avatar
Holden53
Did you check the wheel for play when the car is jacked up? This can be control arm bushings and/or wheel bearings.
Old Feb 14, 2025 | 12:18 AM
BigBoomer's Avatar
BigBoomer
Also, did you clean the hub mating surface and the wheel mating surface?
If they are dirty the rotor can end up misaligned with the hub or wheel resulting in brake vibration or wheel shimmy.
Old Feb 14, 2025 | 05:40 AM
70Chevelle's Avatar
70Chevelle
I replaced mine with Advics from Rockauto, no issues. From what I understand, Advics is a OEM supplier and partially owned by Toyota.
Old Feb 14, 2025 | 05:52 AM
ExiledWolf84's Avatar
ExiledWolf84
+1 on advics
A good amount of OEM Toyota/Lexus stuff is made by them. the brakes calipers on my IS350C even had Advics stamped into them in huge letters.
Louczar1
RC F (2015-present)
Jun 21, 2024 06:38 AM
JC07ES350
12
May 4, 2022 05:21 PM
jamesrg87
Apr 20, 2016 04:04 PM
tjj13401
Mar 5, 2006 08:45 PM
tony Stark
Mar 4, 2005 10:49 PM
