LS 430 (2006) AC failure
Old Aug 10, 2024 | 09:57 AM
Oppie's Avatar
Oppie
Unhappy LS 430 (2006) AC failure
The compressor is not engaging .There is no pulsed DC signal coming from the AC amplifier. First started as an intermittent failure. Then no AC and radiator fans not engaging at high speed. Checked compressor by applying 12V directly to control valve solenoid and compressor engaged and generated cold air. Short test as radiator fans not working to provide condenser cooling.
Replaced AC amplifier with used one from e-bay and it made no difference. Measured pin 5&6 Connector A11 measured 13 ohm same as value when measured at compressor solenoid. No voltage present at same pins engine running AC on (this model compressor is always on and cooling is controlled by varying the amount of compression internal ) No error codes on display panel (This is the base model no rear AC) High pressure valve 7.9 ohm outer pins and 4 inner. Ran vacuum pump on system and held vacuum -30 for several hours no leaks.
Note: Heat set temperature needs to be 28 or higher instead of 24 as in the passed. (odd)
AC relay tested good in fuse box #1. and all fuses I could Locate associated with AC system and they are all good.
Where to look next?
Old Aug 10, 2024 | 01:05 PM
alextv's Avatar
alextv
Check the fuse box in lower left for water damage which causes a lot of problems. It would take an actual schematic to see what fuse is controlling the problem as many of them are associated with the system working. The radiator fans not coming on is another clue.
Old Aug 10, 2024 | 06:39 PM
tammap's Avatar
tammap
Where to look next?
Do you have 12V at PNK and YEL/BLK wires? Compressor solonoid valve resistance
at pin 1&2 should be 10-11 ohms
Old Aug 10, 2024 | 08:20 PM
tammap's Avatar
tammap
Check pin 21 of the AC control assembly for 12V, this is BLK/YEL wire.
Old Aug 10, 2024 | 08:39 PM
tammap's Avatar
tammap
A complete AC diagrams
File Type: pdf
Old Sep 11, 2024 | 09:41 AM
Oppie's Avatar
Oppie
Default More Diagnosis
Away for a while surgery.
How does the system know when there is not enough AC fluid in system.
There is no low pressure switch. Compressor type changed in 2004 no clutch
A component is disabling the signal to the compressor as well as the fans.
No water damage found fuses and relay all check out good.
Before total failure note on gauges low pressure side wildly swing from 40 to 20 psi.
Did not do this when refill earlier in the year.
Original leak caused by de-lamination of rubber hose low side.
I have also bought a Vac pump and run a vac test. no leak holds vac for hours.
I did see some water vapor boil of.
mrmonster
RX - 4th Gen (2016-2022)
Jul 7, 2023 02:56 PM
plckid
Apr 22, 2022 02:21 PM
pdavid2204
LX - 3rd Gen (2008-2021)
Dec 6, 2017 09:29 AM
hazepurple
Nov 27, 2011 07:48 PM
cleethree
Aug 2, 2010 03:44 PM
