Timing belt
Old Aug 3, 2024 | 09:21 AM
mpierson's Avatar
mpierson
5th Gear
Default Timing belt
Just bought a 2004 LS 430 it has 160,000 on it. Timing belt was done in 2013 at 80,000 miles. Should I do the timing belt again?
Old Aug 3, 2024 | 09:51 AM
LS430Lexus's Avatar
LS430Lexus
Yes. While you are at it, the water pump, radiator, tensioner and hoses. You are due based on time and getting close to being due based on miles. Not an immediate need but I would get it done within a few months.
Old Aug 3, 2024 | 02:07 PM
DrVlikhell's Avatar
DrVlikhell
Congrats on the new car! If you can figure out the brand of belt, and if it's a good one like an OEM Toyota, Aisin or even a Napa belt, you're probably good for a little while. That said, it can't hurt to change it if you're in the position to do it now. I changed the timing belt on my friends car, an 01 with 220k miles, it was over 100k miles overdue. The only reason I know it had been changed at all is because it wasn't an OEM belt. It didn't have any cracks or missing teeth, but there was a lot of rubber dust on the inside of the cam gear covers.
As mentioned above, always do the water pump and tensioner along with the timing belt, they come together in a kit. But also at your mileage I'd also replace all the timing belt idler pulleys with with OEM or Aisin ones, including the one on the spider legs that isn't included in the kit. If any of those idler pulleys start ticking or wobbling, you have to do 95% of the labor of replacing the timing belt all over again just to replace one of those idler pulleys.
andy3256
IS 500 (2022-2025)
Jan 5, 2024 09:34 AM
jdang0118
Dec 24, 2021 07:40 AM
Fabbysgud
Apr 17, 2021 09:06 AM
beehivejug
May 28, 2017 03:25 PM
vs1979
GX - 1st Gen (2003-2009)
23
Jun 27, 2013 04:43 PM
