Timing Belt Replacement/Labor Cost
Old Jun 23, 2023 | 03:45 PM
bradland's Avatar
bradland
Originally Posted by lorenr
If you read this web site, you should understand all of the comments owners have added over the years.
There is no cheap way to do this. Parts are not expensive.
Loren
Ahh, but there is...
Buy the necessary parts and tackle the job yourself eliminating the high cost of labor.
This might be a good topic for a new poll thread. How many forum members do the work themselves vs paying a dealer or indy shop...?
Old Jun 23, 2023 | 09:47 PM
sdwtchlvr's Avatar
sdwtchlvr
Originally Posted by Bocatrip
Who did the work for you? An independent shop?
yes, local shop in San Diego.
Old Jun 24, 2023 | 02:05 PM
TwentyMax's Avatar
TwentyMax
10th Gear
Hey Bocatrip,
Last summer I replaced my timing belt and cam seals on my 430. I do have a thread on my journey working on it. (This is the link to the post) https://www.clublexus.com/forums/ls-...-my-ls430.html
It took me a couple of weeks to do it because I had other things going on during that time. If you are consistent and patient, I would say 2-5 days if you worked on it straight and depending on your pace.
It might not be perfect due it being my first post on this site at the time. If you have any questions on it, please feel free to ask and I'll try my best to respond and help out.
Max
Old Jun 25, 2023 | 04:38 PM
Bocatrip's Avatar
Bocatrip
Hey TwentyMax. Thanks so much for your very extensive and detailed timing belt replacement thread. Unfortunately, the days of my undertaking such a task are long gone. Good for you, and It should be quite helpful to any forum members who are mechanically inclined. I will be leaving the job to a qualified shop familiar with our engines. Great thread!
Old Jun 29, 2023 | 02:48 PM
Duck05's Avatar
Duck05
Originally Posted by Duck05
My independent shop is doing the service while they are replacing the blown radiator so I won’t likely see it. I will ask when I pickup the car tomorrow. The belt was changed at 178k prior.
The belt by itself was in the shape expected (not chewed up by ready to change) but the WP was leaking so it was time to do the service. While they had it went ahead and replaced a worn wheel bearing (fairly expensive repair) but the results completely restored the totally quiet cabin.
Hope not to have any further items for a couple of years…..
Old Jun 30, 2023 | 06:43 AM
alextv's Avatar
alextv
If only 1 wheel bearing hub was replaced it won't be long before other side will need it also. It is extremely easy to replace and took about same amount of time as pulling tire off and on with same complexity. I bought 2 for around $70 for pair (not Lexus) and work perfect.
Old Jul 9, 2023 | 06:26 AM
lp2k's Avatar
lp2k
I’m in Orlando and did mine and can knock it out. DM and I’ll work a good price for you.
Old Jul 24, 2024 | 04:43 PM
Bergubby's Avatar
Bergubby
1st Gear
Default Indy Shop
Originally Posted by Freddy12
Here in Toronto the whole job including parts and labor was 1200 CDN. Parts were OEM , serpentine belt included, approximately 6 hours more or less. Indy shop. Lexus quote was double. Hope that helps
Freddy , Do you have an address for this shop or phone # Thx Bergubby
Haris5
GX - 1st Gen (2003-2009)
23
Mar 16, 2023 03:57 PM
aydogdu197
Jun 23, 2022 08:24 AM
Makiavelo7
12
May 18, 2017 02:01 PM
rennwerkes
Jul 29, 2011 01:53 PM
LeXuSrAcIn
RX - 1st Gen (1999-2003)
Oct 23, 2006 08:00 AM
