Oil pump replacement
Old Jan 26, 2023 | 11:40 PM
Ls400gibbs's Avatar
Ls400gibbs
1st Gear
Default Oil pump replacement
Should I replace the oil pump while I知 doing the water pump and timing belt I値l have everything off and out of the way my car is a 97 with 197,000 miles
Old Jan 27, 2023 | 07:54 AM
fondu's Avatar
fondu
Originally Posted by Ls400gibbs
Should I replace the oil pump while I’m doing the water pump and timing belt I’ll have everything off and out of the way my car is a 97 with 197,000 miles
It is possible to remove the oil pump with the engine in the car however it is not simple and can cause more leaks since the sump pan can not be removed with the engine in the car. The oil pump is not a wear item on these engines and typically they leak (very minor) from the small o ring at the top of the pump after so many years and mileage.
I'd say leave it alone.
At about 5 minutes in until the end of this video they explain why its complicated and not recommended -
Yri
IS F (2008-2014)
Mar 17, 2020 05:55 AM
spo0k
Mar 19, 2018 10:45 AM
carlover
Feb 20, 2012 08:55 AM
soarer479
Dec 4, 2010 11:51 AM
sc3dreamz
Sep 26, 2006 09:25 PM
