97 ls 400 sat for two years help
Old Jan 16, 2023 | 06:46 AM
atticus42's Avatar
atticus42
1st Gear
Default 97 ls 400 sat for two years help
Hey all,
I have a 97 LS400 that’s been sitting for almost two years due to the starter (I know, I know, some unfortunate life events have kept me from working on her), I have the starter, new tires, new batteries, and I’m looking at purchasing new fuel system parts.
I know before I start her I need to clean my fuel tank, probably new fuel pump and fuel filter, is there anything else that needs maintenance/replacement just due to lack of use? 230k miles, ran like an absolute dream a year and a half ago.
My long term goal with this car is to emulate Ryan Coffel’s LS400, minus the stance (maybe even more width), in a silver and black color way, I have a turbo manifold for my engine, but no turbo or related upgrades for it yet.
TLDR; 97 LS400 sat for year and half due to starter, new starter, tires battery in hand, due to how long the car sat, what else needs to be maintained/replaced?
Thanks y’all.
97 LS400
2003 2500HD Chevy LB7
2005 slammed F150
Old Jan 17, 2023 | 11:03 AM
timmy0tool's Avatar
timmy0tool
starter first, change engine oil, and check trans fluid condition. batteries and tires yes. i would just drain the fuel and put fresh unleaded to see if it will run before replacing the pump. check condition of the brakes and brake fluid and replace if necessary.
get her roadworthy first before modding.
Old Jan 17, 2023 | 01:56 PM
ExiledWolf84's Avatar
ExiledWolf84
If you have the time, pull all 8 of the spark plugs and either pour in a smidge of oil into each hole, or buy a can of fogging oil and give each of the cylinders a quick shot of it.
If you can, rotate the engine over a few times by hand to help spread the oil out, which will help lubricate the upper cylinder walls after sitting for so long. Then when it starts, it will burn off the excess oil almost immediately.
Old Jan 18, 2023 | 08:42 AM
Losiracer2's Avatar
Losiracer2
I would also flush the coolant before any long drives or regular use, first start up it should be ok as long as it doesn't appear dirty and used up. Toyota Red is the stuff to use. Should be changed every 2 yrs and 24k.
LS400Lucas
Jan 27, 2022 01:21 PM
Superfast1
Sep 19, 2019 09:12 AM
dreiter
Aug 7, 2018 01:54 AM
jayturk99
Dec 8, 2009 09:42 AM
CHGO5OH
Oct 28, 2009 02:53 PM
