Torque Converter Failure
I did some research on here and it turns out people had good luck with using the Fel-Pro gasket which is what worked for me. The key is to flatten the area around the bolt holes as much as possible with a hammer before reinstalling. If your pan has been dropped it was most likely torqued past the factory specs along with being pulled on to remove it which both warp the pans edges. 6-7 ft-lbs(70-90 inch-lbs) is the highest you can go with the bolts which will require a proper torque wrench.
I started noticing the torque converter slipping whenever I backed out of my driveway & put it into Drive. It also happened at the traffic lights & during stop & go traffic. There's a distinct delay of a few seconds as the tranny was trying to find its gears. If I happened to step on the gas too much & since the torque converter was slipping, I could hear the engine rev'ed up then the car lurched & trembled a bit. Once it's in gears & rolling, it's drivable. I initially drained & filled the tranny with fresh Toyota Transmission Fluid Type T-IV, it helped for a little while, however the condition got worst to a point it became annoying & also a safety issue so I went with a completed tranny overhauled & I'm glad that I did.
fordstone
May 27, 2019 04:27 PM
340massive
Oct 13, 2015 09:20 PM
