Ls400 starter replacement question
Old Jul 28, 2022 | 04:14 PM
Wesley227's Avatar
Wesley227
10th Gear
Default Ls400 starter replacement question
Okay here it is a 98 Lexus LS400 starter it needs replacing but will that fix the problem easpecially with the teeth grinder down like that
File Type: mov
Old Jul 30, 2022 | 10:59 AM
CLLEXUSS's Avatar
CLLEXUSS
It should! Looks like the starter main bearing assembly gave out, thus throwing the whole shaft out of alignment. Only thing you can do is try to inspect the flex plate teeth while the starter is out, if no teeth are missing or severely damaged on the flex plate it should be fine. You'll have to rotate it 360 degrees around in increments to try and visualize all the teeth by rotating the crank bolt a little at a time with a socket and ratchet.
Horsepwr
12
Oct 6, 2023 12:56 PM
Superfast1
Feb 17, 2021 09:07 PM
billydpowe
Sep 16, 2019 07:21 AM
skperformance
Jun 9, 2009 10:05 AM
