What are necessary steps before slamming ls400??
so my coils otw and i’m planning to go on washers when i take the necessary steps i just need more knowledge on them. i know i have to raise my fuel tank and also relocate sum wires that sit on the subframe. If anybody has any tips or tricks for those 2 problems please let me know anything helps i’m going into this blind I haven’t done my research yet posting this here first… also if there are other things i need to watch out for please lmk. thank you
what coils did you go with? and washers? not sure where washers come into play...
it doesn't take much to get these cars to get fairly low (which most of the members here does not do). just run the coils out of the box and see if you like the way the car sits. how it will ride is another issue...
if you want to go SUPER low like what you see in japan/internet, that is a whole other ballgame that coils alone cannot do.
and the fuel tank is inside the car directly behind the rear seat, so there is no raising of the fuel tank necessary at all!
plus the only wiring you need to worry about is around the front fenders, but you will never hit them if all you have added are the coils. the suspension will max out before the tires can make contact with the wiring.
287Klex
Apr 3, 2014 12:48 PM
