Steering Rack Bracket Mounting Bolts
Old Feb 7, 2022 | 05:09 PM
YODAONE's Avatar
YODAONE
Default Steering Rack Bracket Mounting Bolts
When servicing your steering rack, inspect four bolts with captive split-ock wave-washers which affix two brackets onto the front subframe which clamps onto steering rack tube rubber grommets.
After 23 years, these split wave lockwashers on 1999 LS400 have lost tension and flattened, so am replacing bolts as part of my steering damper installation project.
Four Steering Rack Bracket Bolts part number 90119-12173.
Split in split wave spring lockwasher (closest to underside of bolt head) has lost tension, so no longer raised...and lost it's "bite".
New bolt depicting waviness in split lock wave washer. Excellent design. Shiny coating is Fluid Film.
Old Feb 8, 2022 | 09:07 AM
timmy0tool's Avatar
timmy0tool
with all the maintenance you do, i'm surprised you don't have grimier fingernails! nice work on the minute details as always!
06gxdriver
GX - 1st Gen (2003-2009)
Mar 29, 2020 11:02 AM
D3AN
Jan 12, 2018 05:00 AM
TallerMike
Oct 24, 2007 11:07 PM
