Rear light......
Old Sep 15, 2003 | 05:31 PM
nmarcks's Avatar
nmarcks
Default Rear light......
I'm looking for some direction on what to do next........
Recently my rear lights closest to the license plate on both sides went out. I changed the bulb and no luck. Both sides do not work now. Two days ago the one side did work. Pulled bulbs and they look fine. So I put two new ones in (7440) just like what came out and no luck. Was looking in the manual to check the fuse but the same fuse is use for all the rear parking lights so I doubt its that.
Any suggestions???????
Thanks.
This forum is so helpful with stuff.
Old Sep 16, 2003 | 05:41 PM
rajah996's Avatar
rajah996
Lift open your trunk. Look at the arm on the left (drivers) side. There
is a black plastic piece on it, pull it out, and you will see wires inside
the arm. THose are the wires to your brake lights. Trace those down to
near your rear deck. You will probably see the wires are brittle and cut.
Repair that with a little soldiering and your good to go. Hope this helps.
-R
Mrv8q
Sep 16, 2018 02:48 PM
Heavy
Feb 28, 2012 06:45 AM
quaiduhm
May 12, 2011 11:42 PM
tlsmikey
RX - 1st Gen (1999-2003)
Sep 18, 2009 10:40 AM
