View Poll Results: Clean or replace
Clean
100.00%
Replace
0%
Voters: 5. You may not vote on this poll
MAF, clean or replace?
Old Oct 14, 2020 | 10:05 AM
Sin1UZFE's Avatar
Sin1UZFE
Originally Posted by YODAONE
It is different which explains my reason for suggesting it.
The Celsior emissions system is not as complex as the LS400, nor does it appear to employ a charcoal canister.
There are fewer parts (hopefully not discontinued) that might be configured.
While this changes the emissions function, Toyota elected to discontinue a critical emission component at exactly the time when many are just beginning to fail.
So what is the solution?
Used charcoal canister haven't worked. If I go the celsior route will there still be a code? My car passes emission regardless just drive to set monitors and clear cel. Passes lol.
Old Oct 14, 2020 | 10:23 AM
YODAONE's Avatar
YODAONE
Perhaps Yamae can recommend a component that spares the trouble code from triggering in the first place. A resistor perhaps?
Old Oct 14, 2020 | 11:12 AM
Sin1UZFE's Avatar
Sin1UZFE
I would definitely appreciate that
Old Oct 14, 2020 | 11:59 AM
YODAONE's Avatar
YODAONE
Located Celsior UCF21 info....
Charcoal cannister is 77740
Celsior UCF21 vacuum diagram
Celsior UCF21 charcoal canister appears to be available.
Old Oct 14, 2020 | 12:02 PM
YODAONE's Avatar
YODAONE
Old Oct 14, 2020 | 01:35 PM
Sin1UZFE's Avatar
Sin1UZFE
AWESOME! also seems to be over 50% cheaper
Old Oct 14, 2020 | 06:31 PM
YODAONE's Avatar
YODAONE
The charcoal canister depicted is for pre-1998 LS400.., but is shown in parts diagram for 1998-2000 Toyota Celsior (be glad you do not have a 2000 LS400- charcoal canister mounted in trunk and offered one model year)
Why I made suggestion to check Celsior.
It is unclear whether the earlier LS400 chacoal cannister uses a solenoid valve with a connector similar to the 1998-1999 LS400.
Compare the fuel tube diagrams 1995 -1997 vs 1998-1999 LS400.
Unsure if it can be made plug and play.
Anyone with images of 1995-1997 LS400 Chacoal Canister?
Old Oct 14, 2020 | 07:10 PM
Sin1UZFE's Avatar
Sin1UZFE
I put in 77740 50050 and it shows compatible for my ls. But then again it said the same thing of 77740 50082 lol
Old Oct 14, 2020 | 07:26 PM
YODAONE's Avatar
YODAONE
How about this image..NO charcoal canister.
Never trust compatibility reports.
Obtain VIN of donor vehicle and have dealer run your VIN to insure correct component.
What the heck can fail inside a charcoal canister besides the activated charcoal?
Can these things be cut open and activated charcoal replaced?
Old Oct 14, 2020 | 07:27 PM
Sin1UZFE's Avatar
Sin1UZFE
Don't know if it can be replaced but I'd rather have no canister. But the issue of cel remains
Old Oct 25, 2020 | 10:42 PM
Sin1UZFE's Avatar
Sin1UZFE
Yamae
Any suggestions? Possible?
Im pondering a charcoal canister delete
over40driv
Sep 9, 2022 06:52 AM
DMV703
GX - 1st Gen (2003-2009)
Oct 11, 2020 05:46 PM
socaligs
Apr 1, 2020 12:23 PM
LADavidGS
Jun 24, 2012 05:44 AM
SC400slide
Jun 22, 2012 03:29 PM
