95 LS400 Overheating
Old Dec 4, 2019 | 10:40 AM
Scrrubyyy's Avatar
Scrrubyyy
Default 95 LS400 Overheating
Hello everyone I have a 1995 LS400 and this car doesn't stop overheating. Yesterday I replaced all the coolant sesnors, radiator, and thermostat. I put all new hoses and the switch that goes to the bottom of the radiator. The starter was recently changed not that long ago so I was wondering is there a coolant hose under the manifold that probably got pinched and isn't letting it flow? Thermostat hose does not get hot and doesn't feel like it opens. Clutch fan works but the electric one in the front doesn't kick on when it heats up. Please help.
Old Dec 4, 2019 | 01:40 PM
timmy0tool's Avatar
timmy0tool
overheating usually is caused by improper bleeding (air bubbles in the system).
search on how to do it right, and it takes longer than you think (20-30mins of holding the revs to keep the water moving to extract the air).
the t-stat should open eventually, and run the heater at full blast.
hopefully you installed the t-stat correctly - jiggle pin at the highest point, 12 o'clock.
Old Dec 4, 2019 | 01:46 PM
Scrrubyyy's Avatar
Scrrubyyy
Yeah it's at the highest point the oil is not creamy and Im pretty sure I bleed it right haha
Old Dec 5, 2019 | 04:12 AM
nvturbo's Avatar
nvturbo
Did you make sure you used the right mixture? If you have more water than coolant, that will cause it to overheat as well.
More than likely, you may need to re-bleed the system.
Old Dec 5, 2019 | 08:04 AM
bradland's Avatar
bradland
I'd never recommend using straight water in the cooling system but it will not "cause" a healthy engine to overheat. Distilled water actually has excellent heat transfer properties but its boiling point (100C = 212 F) can make it less efficient if it begins to boil. Bubbles carry less heat away than a steady flow of fluid. Straight ethelyne glycol boils around 197 C = 387 F. Coolant also has anti-corrosive properties added that water obviously cannot provide. In a pinch, if you have no choice, water will do an adequate job of cooling an otherwise healthy engine. Just don't leave it in long term...
The proper mix of coolant (aka antifreeze) with water is most important in the winter months to prevent the mixture from freezing.
Sferreyra9
Nov 27, 2019 01:31 PM
Elless400
12
May 1, 2017 09:16 PM
theubster
13
Feb 20, 2014 01:33 PM
Ascari_2
Apr 1, 2012 08:26 AM
LS4Lexus
Maintenance
Nov 11, 2004 11:50 PM
