Mass air flow
Old Sep 8, 2019 | 09:05 PM
Gcuarino's Avatar
Gcuarino
Default Mass air flow
Hi Guys!
1992 Lexus ls400 102000 miles.
So I ordered a Mass air flow sensor matching part numbers. The one on my vehicle has no thin wires. All the ones I seen on line did. Looks exactly the same except for the I think 2 fine wires
Any thoughts?
Old Sep 8, 2019 | 09:14 PM
Where did you buy the sensor? What brand?
Old Sep 8, 2019 | 09:37 PM
Gcuarino's Avatar
Gcuarino
Default mass air flow
EBAY zhengshaobo 59.89$ unbranded
AUTOFATHER333
Old Sep 8, 2019 | 10:02 PM
Gcuarino's Avatar
Gcuarino
What is the difference between the 24 code and the 31 code for CEL
Hopping replacing the mass air flow will fix both. Hopefull. Thoughts? Thank you.
Old Sep 9, 2019 | 10:14 AM
deanshark's Avatar
deanshark
The code 24 is for the Intake Air Temp sensor which is located inside the Air Flow Meter and can't be changed by itself. The whole AFM needs to be changed. That is why you are getting the code 31 for the AFM signal.
Yes, changing it will get rid of both codes.
Old Sep 9, 2019 | 11:42 AM
oldskewel's Avatar
oldskewel
Our gen1 Lexus do not use hot-wire or film MAFs like that at all. Ours are completely different, based on a Karman vortex counter. More details in an older post of mine at:
https://www.clublexus.com/forums/ls-...l#post10206613
I guess it is possible for someone to engineer a hot-wire MAF that - although being completely different in how it measures air flow - would plug in and interface electrically sufficiently well. But I would not try to be a pioneer in using such a part. If you do try it and it works, please report back.
Also, I know you did not ask for diagnosis help, but did you try running the car with the AFM unplugged? It should run pretty well like that. If it does not, it means you have a problem other than the AFM to fix.
Old Sep 9, 2019 | 12:29 PM
Gcuarino's Avatar
Gcuarino
Default Afm
So the whole assembly right? 2 parts? Looking for a part on Ebay remanufactured
peteman015
May 11, 2017 09:21 AM
sticky4
Jun 25, 2011 12:48 PM
iceman1117
Jul 6, 2006 04:32 PM
