O2 sensor delete
Old Mar 25, 2019 | 09:30 PM
Gcuarino's Avatar
Gcuarino
Default O2 sensor delete
Would like to run a nice exhaust and delete all o2 sensor's. Washington will no longer be doing emission testing. So better gas mileage a little hp gain, nice sound. I also would not like the check engine light to be on because of this. Is there a way to unhook o2s and maybe trick the brain? 1992 Lexus ls400 98000 miles. Thank you for any help.
Old Mar 26, 2019 | 10:12 AM
RA40's Avatar
RA40
Super Moderator
The ECU relies on that data to adjust fuel trims properly. There may be a way to work around this yet that may bring more issues. My suggestion would be to leave it.
Old Mar 26, 2019 | 10:38 AM
HewittTech's Avatar
HewittTech
I assume the OP is talking about the after cat O2 sensors. Yes, the upstream O2 sensors aka A/F sensors are needed for the computer but you can get rid of the rears with an O2 simulator. Basically an O2 simulator plugs/wires into the front A/F sensors and into the harness for the rear O2 sensors to simulate the signal the rear would see if the Cat was still in place to prevent your catalyst efficiency codes and the CEL from coming on. Another trick uses a spark plug plug non-fouler to place the rear O2 into the exhaust stream to reduce its exposure to the exhaust to simulate the signal. Both work find and pick your poison. A quick thread search shows a few things on the topic.
Old Mar 29, 2019 | 07:27 PM
rick1987's Avatar
rick1987
If you don't mind a check engine light.
But what I would do. Leave the first set installed. The engine needs these to run. The computer will probably throw you into limp mode if you disconnect them.
Ditch the Cat. And use a spacer for the rear O2 sensor. They might be called spark plug spacers.
I've used them in previous cars with gutted cats.
Old Mar 30, 2019 | 02:48 AM
Gcuarino's Avatar
Gcuarino
Default O2
Thank you for the info. I do wanna ditch the 2 cats. I don't want to hut them, but rather cut them off and run straight exhaust back. Can i still hook up modified o2s to just a regular round pipe?
JoeBlob
Feb 8, 2018 08:12 PM
RedPhoenix
Sep 16, 2014 09:41 PM
worldforgo
Mar 23, 2011 08:22 AM
flipinsayi
GS - 1st Gen (1993-1997)
Aug 19, 2009 05:48 AM
wifeses300
Feb 7, 2007 10:42 PM
