Ujoints
Old Jan 19, 2019 | 07:40 PM
Sin1UZFE's Avatar
Sin1UZFE
Default Ujoints
Rockauto doesn't have any for my 99 ls400. Anyone have a source for them? I need to replace the center mount and both front and rear ujoints.
Old Jan 20, 2019 | 06:37 PM
YODAONE's Avatar
YODAONE
There is one center u-joint with front and rear rubber disc's or "guibos" at transmission and differential, respectively.
The center u-joint is not a dealer serviced item, so if it is bad then driveshaft section replacement is required.....however I have a guy with expertise replacing Toyota/Lexus center U-joints.
Buy OEM guibos or be disappointed with aftermarket.
Old Jan 21, 2019 | 02:33 AM
spuds's Avatar
spuds
https://www.clublexus.com/forums/ls-...le-solved.html
https://www.amayama.com/en/genuine-catalogs/lexus/ls400
https://lexus-usa.epc-data.com/ls400.../chassis/3701/
Old Jan 21, 2019 | 12:20 PM
Sin1UZFE's Avatar
Sin1UZFE
Many thanks, now that I have the part number maybe I can find a used one.
Old Jan 21, 2019 | 12:51 PM
Sin1UZFE's Avatar
Sin1UZFE
Does the 97 have the same shaft
Hoovey689
Mar 21, 2014 03:55 PM
Hoovey689
Oct 2, 2013 02:20 PM
Hoovey689
Apr 12, 2013 02:53 PM
Hoovey689
Mar 16, 2013 03:10 PM
