Steering Wheel Odd Behavior
Old Dec 16, 2018 | 03:23 PM
Moarpower's Avatar
Moarpower
Default Steering Wheel Odd Behavior
My steering is being weird.
Wheel will center, IL take a right turn and then when I straighten up, it will be turned to the right. The same happens is I take a left.
Old Dec 16, 2018 | 03:52 PM
EthanS's Avatar
EthanS
Either your lower control arm bushings, steering rack bushings, or tie rods are bad. Just my 0.02.
Get the front wheels off the ground and start muscling the wheel/tire at 12 and 6 oclock positions back and forth. Then try it again at 3 and 9 oclock. Best to have a buddy with a flashlight looking at the suspension assembly while youre wiggling to see exactly what it is.
Old Dec 16, 2018 | 04:25 PM
RA40's Avatar
RA40
Super Moderator
Had similar on a past car...worn rack bushings. Check the others as EthanS mentioned.
Old Dec 16, 2018 | 04:43 PM
valex's Avatar
valex
When I changed the rack bushings on my 1999 LS a few years ago, the old ones didn't look bad at all, but what a difference in steering after I installed new ones! A lot less play in steering going over bumps and rough road.
The two bushings are different ( right and left) and about $15 a piece OEM.
Old Dec 16, 2018 | 07:12 PM
Moarpower's Avatar
Moarpower
Well looks like I'm getting under it again.
It does have a PS leak on the rack somewhere Maybe time for a whole new setup
Old Dec 17, 2018 | 09:26 AM
timmy0tool's Avatar
timmy0tool
yeah the rack bushings are giving play so the steering wheel won't center properly.
I also saw a similar behavior on my Tacoma just before the front lower ball joints gave out! I would definitely check them while down there as well.
Bon
Aug 13, 2021 07:51 PM
BoostAddct
Oct 28, 2011 09:29 PM
MIGS
Nov 14, 2010 06:25 PM
TomLee
Apr 3, 2010 04:04 PM
cspradlin
Jul 16, 2009 12:58 AM
