distributor cover removal 91 ls400
Any tips on getting driver side cover off Can only see one bolt I know there must be three.Already removed top radiator hose
What do you mean by distributor? These don't use a traditional distributor. They use coil packs and distributor rotors.
Are you talking about the cover that cover the plugs and the cap?
Pretty sure he's talking about the timing belt cover which covers the distributor.There's actually 4 bolts. This will show you the steps http://www.lexls.com/tutorials/ignition/sparkplugs.html Step 15 is probably the bolt you can't see. You will need an extension and a swivel adapter for your ratchet.
And COIL PACKS ? Sorry these are not COP ignition systems. Coil On Plug. And they can be referred to as packs. Most cop automotive systems do not use a rotor to supply the current they are electronically fired.
kouji
08-06-12 05:39 AM
