Running hot question
Old Oct 2, 2017 | 05:18 PM
mercedes84's Avatar
mercedes84
Default Running hot question
My 1991 LS400 ran hot on me one day and every time after that it runs hot after about 15 minutes. I thought I blew a head gasket and put in some gasket sealer but it's still doing the same thing. Today I did a compression test and all 8 cyl. are close to 175psi. The fan clutch is new, the water pump is new, the thermostat is new, I put a garden hose through top radiator hose and ran water (thermostat out) through the top radiator hose through the engine and back out the bottom radiator hose and it seems to be flowing free. Am I missing something here
Old Oct 2, 2017 | 05:21 PM
timmy0tool's Avatar
timmy0tool
there is still air stuck in the cooling system. there is a certain way to remove the air, see below on how to properly bleed the cooling system:
http://www.lexls.com/tutorials/cooling/coolant.html
Old Oct 3, 2017 | 08:46 AM
YODAONE's Avatar
YODAONE
Check water control valve (located center top of firewall engine compartment.) for leaks..
Had a 1993 LS400 running a little hot...placed a paper towel underneath it and was stained red from coolant.
Also, check front of fan clutch for dust/dirt build-up...if the bimetal coil is clogged then it may cause it to not engage to cool engine..
magneti
Oct 8, 2024 12:08 AM
xeus
Nov 4, 2017 11:34 AM
Brian1982
Sep 29, 2010 05:23 PM
lanthern22
GS - 1st Gen (1993-1997)
Jan 6, 2010 08:31 AM
JspecSC3
Jun 22, 2006 07:42 PM
