NEED WHEEL BEARING BRAND and P.N.s
Toyota uses quality wheel bearings and have replaced left front on 99 LS400 using OEM parts.
Contemporary bearings offer improved materials and lubricants over 20-30 years ago, so am investigating upgrades.
Anyone have OEM brand and P.N. or images of front and rear wheel bearings on 1995-2000 LS400?
Would also consider pursuing upgrades for the OEM serpentine belt idler and tensioner pulley bearing exists (not the whole assembly, just the bearing).
The bearing are good quality but possibly quieter variants exist offering same durability .
P.N.s appreciated for 1995-2000 LS400
Really impressed with the Nachi replacement bearing installed on my AC compressor clutch pulley...much tighter fit on AC compressor shaft...zero wobble.
Have an interested engineer there ...
These are some KOYO OEM front wheel bearings I found. 90903-63006 I think is the P/N. I think Nachi was the brand that I removed on my 97 w/ 278k miles. I found these on Amazon through a seller called classicgarage.com. The 98+ ones are different than 95-97 though, the bore on the 98+ is 1mm bigger on the hub, so i'm unsure of the later year P/Ns
They're new old stock, but are very high quality, just as good if not better than Nachi
biacs
11-23-15 08:17 AM
