Power Steering failure - UCF20
Old 11-07-16, 08:29 AM
Drewry929
Drewry929's Avatar
Default Power Steering failure - UCF20
My wife and I have had our LS400 for about a month now, and decided to take it to our first ever autocross event. Well, half way through the second lap, the powering steering went out and I limped back to the paddock. At idle and low speeds, the car groans when turning the wheel. Even turning the wheel, while stopped, just a couple degrees and holding it causes a groan, as if the PS is trying to help.
This marks the third time the PS has gone out, the first two were when I drove it 8 hours home from picking it up. I let it sit for awhile the first two times (over night, and around 2 hours) and it started working again. This time, not so much luck.
Any thoughts on what happened and if the autocross could've caused it? Maybe some air in the system? I checked the fluid level and it looked ok. I plan on doing a flush ASAP, and hopefully that will fix it, but do you guys have any other experience or ideas?
Old 11-07-16, 12:00 PM
m0ist
m0ist's Avatar
Sounds like there is a leak in your system and you are out of fluid. Get under your car to see if you can spot where the leak is coming from.
Old 11-07-16, 12:02 PM
billydpowe
billydpowe's Avatar
remember do NOT put power steering fluid in it.. dexron III toyota transmission fluid
Old 11-07-16, 03:45 PM
dicer
dicer's Avatar
"The power steering went out" Isn't that like saying my car don't want to work no moe, can anyone tell me whats wrong with it?
So what part of the power steering went out? The rack? The pump? The hose over there or the one up there? You where just driving a poof it stopped working?
Maybe the pressure relief spring broke?
Old 11-07-16, 08:11 PM
Banshee365
Banshee365's Avatar
dicer, where is my oil leak? It's leaking oil, I think.
j/k
Old 11-08-16, 01:44 PM
dicer
dicer's Avatar
j/k
I need help too my tires start turning when I drive down the street, someone told me that since I don't see them. Whats wrong with them?
Old 11-08-16, 02:05 PM
Legender
Legender's Avatar
I would suspect Power steering fluid is being used instead of trans fluid. Had this happen in a 2000 tundra, when the power steering presumably went out... even thought the reservoir was full. Found a container of standard power steering fluid in the cab. Flushed out the fluid and replaced with trans fluid (dexron) and been working fine every since.
Old 11-08-16, 05:13 PM
dicer
dicer's Avatar
Naaaa come on when I say that about using x brand of ATF in the LS transmissions I get a rash. The fluid can't be the problem. <<<<<<---------- yeah just being funny and giving out what I always get.
Old 11-09-16, 09:33 AM
Kris9884
Kris9884's Avatar
Now I'm confused lol, we should be using ATF instead of PS fluid??
Old 11-09-16, 11:12 AM
Legender
Legender's Avatar
Manual and cap for power steering fluid reservoir both state ATF... I don't think there is any question there.
My experience with the Tundra shows it does indeed make a difference. YMMV... as always.
Old 11-09-16, 12:43 PM
bradland
bradland's Avatar
Smile
PS fluid has the wrong viscosity and thermal properties for LS400 steering systems. It may seem odd to us Americans but Toyota engineered these PS components to be happy with ATF.
Old 11-09-16, 01:17 PM
Kris9884
Kris9884's Avatar
I don't own an LS400 yet so I was just wondering.. Crazy
Old 11-09-16, 02:24 PM
billydpowe
billydpowe's Avatar
no,not crazy, brilliant ..
Old 11-09-16, 03:25 PM
Kris9884
Kris9884's Avatar
Good to know!
Drewry929
Road Course and Auto-X
11-07-16 08:22 AM
spurge
SC- 1st Gen (1992-2000)
01-20-14 10:52 AM
Kakaroto
Performance & Maintenance
09-18-12 05:45 PM
TunerLexx
01-11-11 10:53 AM
lexusben
12-06-10 05:19 PM
Quick Reply: Power Steering failure - UCF20
