1999 Lexus LS400 key issue
Hello
I have a 1999 LS400. Unfortunately I have lost the main key (with the button fob) and only have a key that unlocks the doors (by turning it in the barrel) and turns the ignition. The engine turns with this key but does not start it.
I have spoken to the local Lexus dealer and they cannot make me a key unless I already have a working master/main key.
So, any ideas and solutions are welcome. I'm quite worried about this and need a fix.
Thank you
Thank you
Hello
I have a 1999 LS400. Unfortunately I have lost the main key (with the button fob) and only have a key that unlocks the doors (by turning it in the barrel) and turns the ignition. The engine turns with this key but does not start it. Every time I connect the battery the alarm comes on and does not deactivate.
I have had a key made by a local locksmith which he promised me would start the car however he is now blaming the fuel pump for not releasing fuel into the system. Every time I connect the battery, the alarm comes on and does not deactivate when I put the key into the ignition. The new key (or old one) does not unlock the door with the battery connected. The doors do unlock when the battery ios disconnected. The new key is not a fob key.
Thank you
Thank you
Super Moderator
The 98+ have a transponder chip in the key. The car will not run without the matching transponder key. The car is menat to do this in the absence of that key. The direct solution is to go to a Lexus/Toyota dealer to have a new master key cut then programmed to the car.
You need to talk to more than one person at that dealer, because who ever it was should not be working there.
Maybe Stereorob can give you input on this deal. With the VIN any Lexus dealer can copy the key and look up the reprogramming information, and for that matter a top notch lock smith that has access to the Toyota lock info can do it as well. So you are not talking to the correct people. That is how simple your key problem is.
Super Moderator
Agreed, he needs to talk to another at the dealer. The dealer should have access to the data for the VIN to be able to have the key cut. Don't know what data is shared with locksmiths in the UK. Stateside there are locksmiths that can program the new keys. Will have to call which locksmiths can do new key programming.
I bought a viper alarm and to bypass the key situation i bought a module to bypass it so i could have remote start. that would be a cheaper option. here is a link to one. http://www.ebay.com/itm/IMMOBILIZER-...dmBdtQ&vxp=mtr
