Is this the death sentence to all 1st gen LS400?
Hey gang,
So, after scouring the earth to find knock sensor harness, I only found out that it is no longer made for 1st gen LS. No one in the universe makes it, and no store anywhere on this planet has it.
That means that should any one of us need one (like myself for instance), we are only left with a possibility of finding a used one from another LS, which is likely just as old and brittle as ours.
No other harness is compatible. It HAS to be the one made specifically for the 1st gen LS. It seems that all 1st gen LS's use the same one.
Since many Toyotas and Lexuses use the same knock sensors, I am thinking that maybe we could improvise these wires from some other harness that is most similar to it? Ours (1st gen) has four contacts: two for knock sensors, one to the starter (which should also be the same on many other cars, right?) and one to the engine harness - plugs into it right at the firewall.
What do you guys think? Should we contact some independent shop that makes wires by order and make a group order? I mean, it is just a well insulated piece of wire with four contacts after all... how hard can it be to make one?
If we do not come up with a solution, we are destined to junk our cars the first time they develop knock sensor wire problems, and I would hate to do that.
I imagine if there is enough demand, somebody will manufacture this harness at some point in the future.
You can try contacting these guys;
http://www.casperselectronics.com/st...9c4b2c518d1a5e
Mike
Mike
I'm guessing that there's a break in one wire or multiple wires of your wiring harness for the knock sensor(?).
The best thing to do, and what I would probably do at this point, would be to find where the breaks are and solder the breaks in the wire(s) back together, sealing it with shrink wrap or electrical tape.
If possible, it may be good to remove the harness first, so it's easier to diagnose and work on.
I believe this photo shows some of the harness (attached).
Mike
Mike
But now with Ford using Yazaki connectors on the newer modular V8s and EcoBoost motors, things might get easier.
From what I've seen on the wiring diagrams, the knock sensor wiring is coaxial cable, grounded to the shield.
as times goes on and as these cars get older and older, more stuff will become unobtanium like this. the future of oem parts for Ls400s looks pretty bleak. I have a feeling if we want to keep these cars around for another 25 years we need to get handy and creative. meh..
The summer before last I changed my starter and ordered a pair of sensors and harness. Bought from Sewell.
They sent me the sensors but forgot the harness. Well I reused the old harness we put some shrink tube over the connector and it held tight and fine.
I called Sewell on the connector and they forgot to send it was a kit with sensors. I got them days later I think they are hiding in my garage.
I will look hard for them tonight,
On a side note my 92Ls was totaled a month ago so I have since moved to a 07LS460L. It is a thing of beauty.
Possible business opportunity for someone? Start collecting salvaged parts now and preserve them for future needs? As long as there is a demand then some entrepreneur is going to supply. Just for fun I looked up Datsun B210 parts to see what was available. Amazing to see how many aftermarket parts and used parts are available. I'm sure the aftermarket companies will come through once Lexus no longer provides....as long as us owners provide the demand.
BahHumBug
you guys act like old connectors can't be reused and harneses can't be remade. These are electrical components, and there are hundreds of them sitting on shelves across the globe, if not thousands.
The LS400 wasn't a niche market car, tens of thousands were made. On top of that the toyota supply chain isn't a small thing. Comparing parts availability to something made in the 40s/50s that were not made to the same standard and quality is pointless.
Maybe in 30 or 40 years will you have something to worry about.
As for making a new one, it may not be as straight forward, but I am sure it can be done. Just don't know who would do it, and do it well...
