Need thoughts on
Need thoughts on
So I'm looking at getting a 91 LS400. Spoke with the seller. Everything comes out clean and good so far. No power steering leaks. The cars timing belt was changed back in 2011 when it had 148K miles. Now, it's got 165K.
I'm wondering, with all normal conditions, even though the car put on low miles since the belt change, it's been more than four years since. Would that be a concern? Is there a high chance that belt can go bad just because it's been driven very less in a long amount of time? Recommend visually inspecting the belt? Just wanna get some advice before I actually go see it myself. Any thoughts?
P.S. sorry messed up on title.
Interval is 90k mi or 6 years. You're under both. Visually inspecting is def. recommended but it's a pain to get to, not something you would do pre-purchase due to the amount of labor and wrenching. That said my latest belt has 90k and 10 years on it... still holding up lol.
The good thing about your model year is a non-interference engine... so if the belt pops it won't damage the engine internally.
If its a cheap old car why worry about the belt? Like everyone says if you want a better LS with better gas mileage get a 98 or newer. And they don't cost much more than the older ones and have more features.
But I didn't know the 98-2000 gets better mpg. I've definitely seen them go for almost the same price as some of the 90-94 goes. But good to know. I haven't done much homework with the newer LS models. Thanks.
Well yeah cheap and I wanted it to stay that way lol. Don't wanna get into replacing timing belt just after buying it.
I would just drive until you feel comfortable. If it breaks, the worst case is just a tow to a local garage or your home to get it fixed. Non interference is a good advantage of the 90-94 models, don't really have to worry as much.
I would just periodically check under the covers for any cracking and if its obvious that its about to go, change it.
I would still do it around the 100k mile mark regardless though.
I'd just drive it... I've got 36k on my Honda Valkyrie with the same timing belt and it's almost 18 years old... I know car vs motorcycle, but you get the idea.
I'm with Billy... have 207K on my new to me 98 and after some maintenance upkeep items, runs like new and use it as my daily driver...when I don't take the Miata.. :-)
timing belt is fine. i worry about mileage over age. age is more of a factor in states that see high temp fluctuations and extreme temps. but even then, it's hard to say since the belt is internal not exposed to the elements.
a good quick check is to see the condition of the serpentine belt (though of course this assume it was only replaced with the timing belt, and not done sooner).
Beberle
04-13-15 03:00 PM
sayow
12
05-01-14 11:45 AM
d1drift
12-05-06 08:03 AM
