Kik down
Old 08-10-14, 12:24 AM
xmel012
xmel012's Avatar
Default Kik down
Guys, have problems with kik on my LS 400 98 ucf 20/21. some time ago i had problems with check vsc. i installed throttle from celsior(japan-the problem was solved . but now when i kik my pedal rpm reachs only to 5000 and and then it is breakdown sharply. I have no cheks. whats the matter???
Old 08-10-14, 09:56 PM
UNCNOR
UNCNOR's Avatar
What is "kik down"?
Old 08-10-14, 10:57 PM
Yamae
Yamae's Avatar
Sounds like the throttle unit is not quite good or does not match to your car.
Measure the resistances of 2 sensors below attached to the throttle body.
The throttle position sensor should show around 1.8 kΩ between terminals 1 and 4. Also check the resistance change of terminals 2 and 3 rotating the valve and confirm there's no abnormal resistance jump or glitch.
The similar thing can be said to the accelerator position sensor, but the resistance should be about 2.5 kΩ between terminals 3 and 4. Also check the resistance change of terminals 1 and 2.
EMCM
Performance
15
09-10-21 04:31 PM
99scMMGT
Performance & Maintenance
10-19-15 09:06 AM
stockhatch
17
12-19-11 03:50 PM
frankjames
05-12-09 06:00 PM
2JZSoarer
08-08-04 03:31 PM
Quick Reply: Kik down
