Power Antenna Problem
Old 04-10-17, 09:44 AM
lee01san
lee01san's Avatar
Unhappy Power Antenna Problem
Hello,
It's been a while when I requested your help for an idling problem. I was not able to pass smog due to idling being too high. What happened was there was a problem w/ the antifreeze thermostat. Inner seal was gone, thus, ECM said never reached the operating temp. I replaced the thermostat and passed the smog.
Now, I yesterday replaced the antenna mast. What did I do wrong? When I turned the radio on, the antenna retracted and vise versa. When I turned the radio off, the antenna extended. What do I need to do for this antenna to properly operate?
Old 04-10-17, 09:20 PM
dicer
dicer's Avatar
I don't know how but it sounds like the cable got wound back wards ?? That's my guess. You will likely have to take it out and take it apart to fix it.
Old 04-12-17, 07:51 PM
Amskeptic
Amskeptic's Avatar
Originally Posted by lee01san
Hello,
Did you do the quik-n-dirty method, or the deluxe method? For the quik-n-dirty method, you need to remove the antenna with radio on for power to the motor. Then extend your new mast and stick the wand in the hole so it engages with the gear drive. Then you turn off the radio and it sucks the extended mast down. If your mast was already contracted, I do not know if the limit switch reverses the motor direction.
Colin
Old 04-15-17, 09:57 AM
lee01san
lee01san's Avatar
Thank you Dicer and Amskeptic,
I apologize for not checking my post more frequently. Okay, I'll take'em a part and put'em back again.
I'll get back to the forum, hopefully w/ a good news.
Old 04-16-17, 11:19 AM
lee01san
lee01san's Avatar
Got it!!
Took'em a part and put everything back. But, still, antenna retracted when I turned the radio on and extended when radio was turned off.
So, what I did was I reversed those two leads (Blue and Black/White) connected to the motor.
Yup, now, antenna extends when the radio turns on and retracts when I turn the radio off.
Hoorey!!
Old 04-16-17, 03:42 PM
dicer
dicer's Avatar
That's just too strange.
Old 04-18-17, 10:27 AM
lee01san
lee01san's Avatar
Hi Dicer,
I just reversed those two wires thinking if I burned the power antenna, I can always get an used power antenna at near-by Pick-n'-Pull (Moss Landing, CA). But, it worked this time without burning the motor. I don't know what I did in the beginning so that the antenna function was reversed. But, I'm a happy camper now! I thank you for your support though!
rosen71
RX - 1st Gen (1999-2003)
14
04-06-16 08:20 AM
Brando
08-07-06 08:47 AM
RX300wannabeIS300
12-17-02 08:59 PM
Quick Reply: Power Antenna Problem
