reset immobiliser
disconnect negative battery cable for a few hours
immobilizer should not care how long your car has been sitting unused - it just cares that you have the correct Lexus key for your car, and that your ECU has not been swapped (theft related stuff)
the immobilizer is really a 3 part system, consisting of the ECU (ECM) and the Transponder Key Coil which is located surrounding the ignition key cylinder area and the Transponder Key Amplifier, which is located behind the radio.
