A few problems- steering, memory and lights
Old Dec 25, 2013 | 06:03 PM
ls400rainy's Avatar
ls400rainy
Default A few problems- steering, memory and lights
Hi
I bought a 1992 LS400 a few months ago and it is a pleasure to drive. The car has 172k miles on the clock.
Hope you guys can help me with some niggles I have, I have tried searching the forums but they do not specifically answer my questions-
1. The power steering column is dead. It never worked, it does not go up or down/ no tilt or telescope. The motor does not sound at all, its as if it is completely dead. Could this be a motor issue, an ignition switch issue or something else?
2. The memory does not save any settings at all. Could it be possible that there is a loose/broken connection somewhere?
3. The lights on the dash aircon controls are partially lit. Is this a case of blown bulbs?
I will appreciate any feedback on the above and if someone can briefly explain me what do do. I am an amateur mechanic/hobbyist so can easily attempt any reasonable repairs on my own with a bit of guidance.
Thanks
Old Dec 25, 2013 | 07:22 PM
LScowboyLS's Avatar
LScowboyLS
first, check the fuse
memory for what precisely?
you need this $30 part and someone who has experience soldering small meticulous things! (45 tiny connections to solder)
Old Dec 25, 2013 | 08:32 PM
dc893's Avatar
dc893
If it is the control buttons then it is just a matter of taking it apart and putting new bulbs in.
Mike246
Oct 9, 2018 08:19 PM
Ozzieblast
Jul 28, 2017 06:39 PM
ronP
Nov 9, 2015 10:22 AM
yusych
12
Nov 14, 2009 08:21 PM
hksnlper
Sep 19, 2007 01:04 PM
