New here...with info
Old 12-02-13, 07:48 AM
bekind
bekind's Avatar
Default New here...with info
I am new here but I wanted to put out some info.about what I have learned from working on my lexus , I own a 93 ls400 , I have had it for 8yrs , and last I remember it had right at 250,000 miles , I say that because the instrument cluster stopped working(lighting up) over a year ago so in order to see how fast I was going I had to have my flashlight handy and all this time no idea how much gas I had and no odometer reading , I also started having fuel issues which I am still working on ...
The car started randomly dying and it got harder and harder to start back up , rpms rise and fall or shoot real high and stay or drop and it dies , and with it being a 93 I had trouble finding a scanner with the right plug so I read where I could read my own codes with a paper clip , so I did ! I replaced the fuel pump and filter , checked sensors and so far have replaced the throttle position sensor , plugs and wires, checked the coils , ignition sensor, and now its come down to replacing the Idle air control valve , and im hoping I can find one cheap ! Ha good luck with that huh?
So, during all this I needed new tires and im thinking great, I need the odometer reading for the warranty on the tires so I pulled the instrument cluster and fixed it myself , there are 3 capacitors on the board that needs replaced , I did that and put it back in and it worked (I have the link if u want it), and I have to admit , I was so happy I did my own touch down dance, anyway, I drove it a day or two and when I went to see about the odometer reading I thought I couldn't get it to come up , it would switch from trip A to trip B but I wasn't seeing the actual miles , well , it was there the whole time reading 252miles , at first I thought it had to have rolled over but theres no way , so I looked it up in the forums and the odometer reset itself when I fixed the dash lights , and the miles are clicking along ... true story !
I got new tires , my dash is fixed , im still working on the fuel issue and its been a long haul...but I am a learner !!! bekind
Old 12-02-13, 08:27 AM
LScowboyLS
LScowboyLS's Avatar
have a look at this thread it may well be "the fuel issue"
there are other caps on the cluster that need replacing besides those three
Old 12-03-13, 08:51 AM
bekind
bekind's Avatar
Wow ...Thank you so much for that info.! I read some where in my search that the Idle Air Control Valve should click or that you should be able to hear it kick in when the motor is started , We are not hearing any thing from the IACV which makes us think it is not working properly or at all , would the ecu /cap.needing repaired cause this ? Is there a for sure way to check the IACV other than listening for it to click ? What would be your next move to locate the issue ? The ecu/cap.replacement or the IACV ?
You don't know how thankful I am for the help here , Im single with little income so Im having to figure this out on my own and then find a way to fix it the best I can ( I don't trust just anyone to work on it) !
Old 12-03-13, 09:08 AM
LScowboyLS
LScowboyLS's Avatar
the bouncing idle issue can be either ECU caps or the Idle air control valve, there are tests to determine which is likely the issue:
Yamae's ECU ripple test
you can also pull the ECU and carefully open it and photograph the inside and let us have a look, you want high quality pics taken in bright light, and be sure to disconnect the negative battery cable before disconnecting or reconnecting the ECU - and when opening an ECU, be gentle and careful and be bare footed and wearing all cotton clothes for static protection!
Idle Air Control Valve test
Hanxious
02-06-17 07:56 AM
MuGGzyx
Performance & Maintenance
15
04-20-14 10:08 PM
zoomnos2
05-30-11 03:12 AM
swatson1
05-16-10 11:58 AM
LiCelsior
Maintenance
20
05-23-09 10:20 PM
Quick Reply: New here...with info
