All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
Old Sep 14, 2022 | 10:40 PM
  #1876
You won't have any problem substituting higher voltage capacitors.
Old Sep 14, 2022 | 11:06 PM
  #1877
DLfpv's Avatar
DLfpv
Thank you, I understand this. But am I right in thinking that the part numbers given in this thread should be suitable replacements for a Es300? It is my understanding that the esr must be the same or lower than the originals, ripple current handling must be the same or higher than original, max voltage rating must be the same or higher than original, and farad rating must match. Which I believe should be true with the part numbers given here. But maybe there is more to it that is beyond the scope of my knowledge.
Old Sep 19, 2022 | 10:36 PM
  #1878
Sunlight's Avatar
Sunlight
2nd gear
Default Can programming key fry those caps?
I hav 99 Ls and rye one and only key for it got stolen, used are locksmith from work to reprogram and do a EEPROM.I was at work when he did it .keys work grate,no security light flashing.,but the car won’t start now.won’t even crank over. The only symptom I had prior was the ac would flash and not work. .now I hav
e no dash no obd connection.I will still plan to get this done,
wonderful thread!I have spent the last two days reading all the post. I have learned a lot from everyone imput, thank you!
Old Sep 28, 2022 | 01:03 PM
  #1879
Stykthyn's Avatar
Stykthyn
1st Gear
Hey guys. New here and this thread is a godsend. I have a 97 ls400 and I've been chasing issues with no real fix. I am not talented enough to attempt this myself. Any pointers towards a company that can perform this service with the correct caps?
Old Oct 9, 2022 | 08:42 PM
  #1880
NotTrue's Avatar
NotTrue
1st Gear
Default Not all true information
First of all, saying you can use only the certain brands, use big bold letters and use the links to order them. That you absolutely get a kick back on is absolutely ridiculous but affective as I a person who has sold and fixed thousands of ECU’s tried to explain facts to someone and all they kept quoting was what I found out is this prestigious forum that refused to believe facts and just would quote this exact thread. To me it’s obvious with the repetitive statements of the capacitors being rare and there are so many fakes out there buy from this link but apparently not for some. I agree there are a lot of fakes, I would never order from China because it’s almost a guarantee. The fact you are allowed to post links to by something and you don’t have to own a Lexus to join shows how prestigious the forums are. Some of what was said was true but there are also other variables like using higher voltage slightly larger caps. Let’s just call it what it is you used some facts mixed in with repetitive fear comments and links so that you would get a percentage of or sales of your own products since they allow third party sellers. Anyone who reads a comment on a forum and takes it as a fact is almost comical. Even what I am saying, anything I have said do some research on. I have no links to get a piece of anyones money so no worries. If you still think there is no way that person would do that and this is a prestigious forum look at my name, also I don’t own a Lexus. Literally anyone can join
Old Oct 14, 2022 | 12:24 AM
  #1881
400fanboy's Avatar
400fanboy
The links in the main post are not affiliate links as far as I can tell. Removing parts of the URL break the link, so there is no embedded tracker which defines an affiliate link.
I don't understand the fear mongering statement... we're talking about parts which cost less than a dollar. It's like $10 in parts to perform this fix. It's not like we're talking about a $799 rebuild fee for an ECU at one specific company who you ship it to. I just don't see the economic value in doing whatever you're accusing people having done... but they go through all this incredible amount of work documenting precisely what the problem is, which is of very specific and rare nature and requires very specific and highly educated knowledge to even understand what's going on, much less propose a solution.
Old Oct 14, 2022 | 04:17 PM
  #1882
as99east's Avatar
as99east
I had a p1600 code on my 95 LS400. Company on eBay called ecmguru performed repairs and sent me photos of leaking capacitors. When dealership popped ecu back in for me, code was cleared and so far, car is running fine. We’ll see how it goes though. One year warranty I think. With tax it was about $180 including shipping both ways.
Old Oct 17, 2022 | 01:56 PM
  #1883
Einzelherz's Avatar
Einzelherz
This may have finally bit my 98 LS400.
Today on the way to the car wash the radio is popping out every couple of minutes for just a second or two. I'm worried it's a loose wire. Then I pull the car into the vacuum station, turn it off, vacuum, and when I got back in, the gages are full dead and no starter. I think the radio was on though. I try this a few times with nothing. Pop the hood to see if maybe the battery got wet, and suddenly it decides to start.
However, the 4 gages are dark and the needles are still. The light on front defroster is blinking for a little bit. The engine doesn't seem rough, but maybe it's a little off. Dash lights seem to be fine (turn signals, etc) and the radio and AC were working. I parked it and put it on a charger cause that's an easy check to do.
I suppose my question is does this seem familiar to anyone? Is there a decent chance the car might leave me stranded until I recao the ECU? I've got the parts, as I attempted it once before. But that time I accidentally lifted a trace and killed the ECU. Had to swap my immobilizer to another which is what is in there now.
Old Oct 17, 2022 | 11:55 PM
  #1884
400fanboy's Avatar
400fanboy
Originally Posted by TaninAuto
We can take care of it for you! We have actual test vehicles on site that we test your Lexus ECU/ECM in before and after repair to make sure we can eliminate any of your reported issues.
Our rebuild service is $179.99 + shipping. ClubLexus members get 5% off with coupon code "clublexus5"
https://www.taninautoelectronix.com/...00-ecu-repair/
General turnaround is 7-10 business days, but we do have a same-day service available for an additional $200. This will get your item repaired and on its way back to you within 24 hours of receipt.
Please don't hesitate to reach out if you have any questions!
Tanin no longer does these repairs .
I'm torn between finding another vendor to send mine out to, or using a local shop I've been too over the years, though they've never performed this exact task before.
What's the general sitrep? This repair is far beyond my skills or tools.
Old Oct 18, 2022 | 07:19 AM
  #1885
deanshark's Avatar
deanshark
Yea uummm, It aint for us common folk.
Don't know if I'd trust someone who hasn't done it before either, it is pretty precise work.
When I was having trouble with my ECU a few months ago, Tannin's website said they no longer repair it. I mentioned that (in a different thread) and they sent me a message saying they still do repairs and thanked me for pointing that out so they could change the website wording. So I'd say give them a call to see what they say.
Or also, a lot of people had good luck with SIA in Illinois for their ECU. https://siaelec.com/
I can't say anything first hand of anyone's work cuz I just bought a used Reman ECU from Denso which works perfect. (got an excellent price) But I have read alot all the years I've been a member here.
Old Oct 18, 2022 | 03:35 PM
  #1886
400fanboy's Avatar
400fanboy
Thanks so much for giving me an up-to-date sitrep of the information.
I have a 98 so I'm at less risk - but the more I read about specifically what is going on here, I want to be proactive about replacing my caps. Because I REALLY don't want to have the headache of what would happen were to them leak, kill my ECU, and then now I have to transplant a new ECU and deal with the immobilizer and all that jazz.
So I just made some local calls around town. Learned some interesting things. I talked to my mechanic who bounced me around to a few people.
There used to be ONE guy who would primarily do this sort of work in the area (city). All of the independents would use him. Nut he went out of business and there isn't really anyone in the city anyone knows of who does board-level soldering work. The demand for it is so low, the shops either turn it away or mail the stuff out. My mechanic can do basic wire-level stuff, but not to the level of familiarity that you'd want for our ECU repair.
What's interesting though - the final electronics shop I spoke with said they have used https://modulerepairpro.com/products...xus-ecu-repair multiple times. Mostly with Chrysler products in their experience, but they've always gotten back quality work from them (says the one guy). I took a look on their website, and they do have services for the 92' - 95' LS400 ECU. Their website doesn't mention capacitors or not. But it's an interesting thing I found I figured I should document here.
Old Oct 18, 2022 | 07:58 PM
  #1887
ankurdave's Avatar
ankurdave
Thank you for this excellent writeup! A few months ago I replaced the ECU on my 1995 LS400 (California) with a used one from eBay (89661-50235) to fix the off-throttle shock issue. This ECU worked perfectly and all capacitors looked OK, but this week I decided to replace them anyway as a preventative measure. I don't have much soldering experience, but I wanted to do it myself, and it seems to be a success. A couple notes:
1. All the recommended 47uF capacitors are out of stock, so I substituted the 63V Rubycon RX30 63RX3047M10X12.5.
2. During desoldering, I had a very hard time getting the solder out of a few of the through-holes/vias. My Engineer SS-02 solder sucker was hardly able to pull any solder out. Eventually I was able to make a small tunnel through the stuck solder by heating it and pushing a sewing pin through.
In hindsight, I'm guessing that the board's factory protective coating was "sealing" the solder in at the other end of the hole, so I could not suck it out. The stuck solder became difficult to melt, I think because of contamination from this coating. Is this a plausible explanation?
If I had to do it again, before starting to desolder, I would thoroughly remove the protecting coating from both sides of each hole using isopropyl alcohol and a bristle brush.
Old Nov 11, 2022 | 04:04 PM
  #1888
andymane's Avatar
andymane
4th Gear
Default Just needing some help
So here recently I've done a timing job on my vvti SC and am having a misfire on all bank 2 cylinders. After doing some diagnostics I got to the ECU and belive I may have a leaky capacitor or two. Does anybody know of anyone who can rebuild one? Been working on this car for awhile and just want to drive it soon.
Just looks like it got leaked on
Old Nov 30, 2022 | 04:38 AM
  #1889
Petan's Avatar
Petan
3rd Gear
Hi, I have LS400 1992 more than 500 000km on it. I read lot of forums, discussion and need some advice.
Few monts ago ABS and TRAC light come on. Steps done and notes:
1) ABS and engine ecu error codes check - no code
2) ABS code check, two times blinks than can be hear relay close to bumper switch off And ABS and TRAC light get on.
3) Tried wheel sensorts check mode, after shift to D or release parking brake fast ABS light flashing (check mode activated) ABS light go on. No codes.
4) Changed ABS ECU by same - no change, same issues
5) Relays under glove box close to ABS ECU switch on when ign go on and holt till ign is on
6) TRAC second trottle selfcheck active when ign on
7) ABS sensors in wheels checked by servis - no failure
8) TRAC high pressure pump and relay not switch on, no pressure in accumulator, but can be caused by not working ABS?
9) brake pedal when is press and engine run is very slowly going down
Any advice what to be check?
abs actuator not working?
Or some ground point?
Or can ba cause by bad capacitor in engine ECU (checked looks ok, not changed).
Thank you
Old Dec 14, 2022 | 11:03 AM
  #1890
Emmetth's Avatar
Emmetth
1st Gear
Default 1995 celsior ecu capacitors
Can you use the same capacitors that you would use for same year ls400 to rebuild the celsior ecu?
