Need help diagnosing misfire 91 ucf10
Old May 13, 2012 | 02:38 AM
  #31
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
both of you quit it, this is your only warning.
Old May 15, 2012 | 02:12 PM
  #32
Garage7RP's Avatar
Garage7RP
Check the spec on the TPS if it is within limits.
When you removed the plastic covers to expose the spark plug wires, did you check al lthe wires if they are in good condition? No break in insulators? Lead wires are good?
Old May 15, 2012 | 05:20 PM
  #33
cobalt91's Avatar
cobalt91
How old is the timing belt?
Old May 15, 2012 | 05:23 PM
  #34
cobalt91's Avatar
cobalt91
got a simaler prob with mine. Just discovered I have 140k on my tb.
Old May 31, 2012 | 04:27 PM
  #35
ocr's Avatar
ocr
So, has this ishue been resolved yet? If so, an update would be much apriciated.. Thanks
Old Jun 1, 2012 | 06:49 AM
  #36
3UZFTE's Avatar
3UZFTE
Misfire...? Ignition problem. No a valve cover gasket (VCG) will not cause a misfire, you've got problems in the ignition system, being plugs, wires, cap, rotor, coils, wiring to ECU could all be possible culprit in a misfire. If your timing belt was off, you'd have different symptoms. I guess if your timing belt tensioner is loosing tension, it would cause the belt to bounce around and change timing depending on where and how the belt was stretching. Check the easy stuff first.
Old Jun 2, 2012 | 05:04 PM
  #37
cobalt91's Avatar
cobalt91
Hows it comin? Any luck?
bboykid10
Dec 1, 2022 08:12 PM
ManuelFdz
Dec 31, 2017 06:58 AM
nateew92
12
Oct 17, 2017 10:48 AM
Barna6vi
Performance
Jun 12, 2015 09:39 AM
josephgary
20
Jul 9, 2012 08:55 PM
