99 LS400 Valve Cover Gaskets
Old 05-19-11, 12:01 PM
ktranne
ktranne's Avatar
Default 99 LS400 Valve Cover Gaskets
Hello. I have a 99 LS400 with 145k miles.
Saw oil leak on and around valve cover gaskets. Had to add 1/2 quart engine oil (been 2k miles since oil change).
beside 2 gaskets and 8 spark plug tubes, what else I need to purchase?
anyone have part numbers for them I can use?
Thanks.
Old 05-19-11, 12:16 PM
steve2006
steve2006's Avatar
I can't see anything regarding the "spark plug tubes" even on the full rebuilt parts list.
The valve cover gaskets are
Gasket Cylinder head Cover 11213-50030
Gasket Cylinder head Cover no.2 11214-50010
Both priced at $29.80
Old 05-19-11, 12:55 PM
oldskewel
oldskewel's Avatar
For my '91, part # 11193-15010 is for the "spark plug tube gaskets", which is probably what you mean.
There are also # 90210-07001 Valve Cover Washers (16 of them - one for each screw).
Again, these are for my '91, your year's parts may be different.
If you're buying a lot of gaskets like this, it is usually a lot cheaper to buy an aftermarket kit that includes all of the above. Gaskets are one thing that I would trust aftermarket parts to do well.
Whatever you do, be sure to torque the valve covers carefully.
Old 05-19-11, 01:20 PM
BIPPUthis!
BIPPUthis!'s Avatar
did you try retorquing the valve cover nut bolts? I retighten mine and it works. Try that first and see if it work depending how bad your leak, if it really bad...move forward replacing them. The driver side is a lot easier to get to than the passenger side gasket ( a little more involve) but not too difficult.
Old 05-19-11, 02:55 PM
akitomk3
akitomk3's Avatar
When i did the job on my 90, i replaced the valve cover gaskets, 8 sparkplug tubes rings, washers, what i didn't do was to re-seal the half moon on the head by the firewall.
Old 05-19-11, 05:05 PM
deanshark
deanshark's Avatar
Check rockauto.com for the valve cover gasket. Their sets include the 8 spark plug tubes and the 16 grommets. They have a Beck/Arnley kit for $47 or a Fel-pro for $37, + shipping of course.
Old 05-19-11, 05:48 PM
tomtheslac
tomtheslac's Avatar
May as well get a PCV valve too, and a throttle body gasket, because it will have to come off. Depending on the state of the vacuum lines, a few of those may need replacing as well. And don't forget the Form In Place Gasket for around the camshaft bearings.
Old 05-19-11, 08:17 PM
bornpeace
bornpeace's Avatar
i will stay away from fel-pro, i used them before they start sipping oil on the spark plug tube gasket(not tight enough like OEM). For 99 OEM spark plug tube gasket is part# 11193-70010(you need 8), left valve cover gasket part# 11214-50011, right is part#11213-50030 and the washer 90210-07001(you need 16) i will also get the FIPG part# 00295-00103 for the half moon thing in the back of the head(they are 4 half moon, take them out, remove the old FIPG, then apply a new one).
The vacuum lines will be another problem because at this time they a hard as a rock. you will know this after the work, also the ignition coil harness clips will break easy.
Old 07-16-11, 06:35 AM
pinkyson21
pinkyson21's Avatar
so is it a must to replace the sparkplug tube gaskets or is it jus like a while you have the covers off task? I didnt think these valvecover gaskets were gunna be a pain like ppl make it out to be. Im not scared of maintenance by any means but ppl on the internet make me want to take my car to a shop
Old 07-16-11, 07:09 AM
deanshark
deanshark's Avatar
It's more of a "might as well" thing. I suggest to do the spark plug tubes b/c when I did my valve cover gaskets, about 15K miles ago, I didn't do my tubes. They were fine then but now they're leaking. If I did them then, I wouldn't need to take the covers back off now. The gaskets aren't too hard to change, this tutorial will help you out; http://www.lexls.com/tutorials/engine/valvecover.html
Old 07-16-11, 08:48 AM
billydpowe
billydpowe's Avatar
I have a set of 8 oem spark plug tube seals, $40 mailed in the 48 states.
direct email is: billydpowell@hotmail.com
I also have a set of 8 Denso PK20R11 plugs $50
Attached Thumbnails 99 LS400 Valve Cover Gaskets-sps.jpg   99 LS400 Valve Cover Gaskets-denso.jpg
harrisbaig
15
04-28-21 08:22 PM
rarebmx4me
Performance & Maintenance
04-24-19 10:45 PM
harvfran
03-22-19 06:07 PM
02msmg3
12-16-10 10:50 AM
VJZ
04-10-08 09:04 AM
Quick Reply: 99 LS400 Valve Cover Gaskets
