Engine will not start
1999 LS400.
I shorted out the alternator 120 amp fuse while changing the spark plugs. Replaced the link. Auto started once, now, the engine spins but will not start. I inspected the engine compartment relay box, looks like lots of current went through the relays. A light brown burn on the relays and base of compartment box. I checked the fuel pump relay for continuity and operation, it is OK. Question: Were is the location, in the factory Lexus repair manuel, for the engine main relay? I would like to ran a test on the relay. Ten days ago I had a new key cut using my old transponder. The new key has started this auto for 10m days. Any other items I might check? Looking for input and ideas. Any help appreciated. |
the main engine relay should be in the engine bay iirc.
Thanks for your reply. I am looking for the page number in the FACTORY Lexus 1999 Repair Manuel.
BTW what is the meaning of iirc? Thanks |
If I Recall Correctly..
