Does Seafoam really work
1 Post
A little dirt can be good for you(your car..I mean) sometimes
The way i do it is, about 100 miles before an oil change i put seafoam in my Vac lines and oil, then a fresh oil change a hundred miles later so it doesnt stay in there and eat away at the internals.......works very well. Also add lucas gas treatment to my tank, also works well
You know I had good luck with it too, I used it on my high mileage 90 Celica and it burnt out some of the carbon deposits in my EGR, fixed some idle problems, Seafoam is about the only snake oil that I endorse!
Many manufactures use similar products to seafoam. If you search, one such product used by GM is called "GM Top End Cleaner". Essentially it is the same logic applied to a slightly different formula of liquid.
I use it in all of my vehicles. From the 1UZ in the Lexus to the LS2 in my GTO and 4 cylinder in my beater Saturn and finally the LT1 in the Z28. Each vehicle seems to enjoy the benefits of the carbon cleaning.
Follow the directions, run it through the brake booster and have fun with the smoke show.
Did you use it in the gas tank or pour some in the crankcase or did you use the vacuum line ingestion technique?
seafoam is the only cleaner that cleans my exhaust tips to shiney metal again when added to the gas. So I know if it does that it is cleaning the rest of the system even better.
To be effective in the gas it needs to be driven at highway speeds for atleast an hour for maximum results idle and stop and go traffic is not going to do it.
I have been using seafoam since it was recommended to me. It gets the jobe done for my engine. Since my car has over 235k miles, I use it every four months and my engine runs like a charm. One of my friends who owns a LS400 said he was going to use Z-Max along with Seafoam--to me, this might be overkill but I'll let you all know what his results were--but for me, Seafoam is more than adequete and yes--I pour it in my gas tank and I've had no problem with my fuel filter...
Before you use Seafoam through the vacuum line, try using water first. Water decarbonization has been around before these solvent cleaners hit the market. To me, it's more effective in most applications, which is probably why I don't buy Seafoam anymore. $8/can vs $0.25/gallon.
The water approach mentioned above does sound reasonable. Anyone else with thoughts on that?
I have not done anything with it, but I came across the following homebrew recipe for Seafoam:
http://hildstrom.com/projects/seafoam/index.html
Hey folks, I'm going to share my seafoam experience. I have to say It works for sure and Lucas gas treatment also works well.
I sucked 6 oz into the brake booster line of both mine and my father's 99 LS's yesterday, waited a little over 15 minutes and started mine up first. "Poof" I was surprised at how little smoke came out, it was like two people exhaling cigarette smoke. Thats it. You have to step on the gas a little upon starting to prevent stalling.
Next up my dad starts his and wow no smoke at all. I was shocked! After a couple minutes of revving we head to our mechanic to get oil changes and drop mine off first. We head to Micky D's to grab a bite, when we started my dads car to head back to the shop, poof he had a little more smoke than mine.
So you may be asking, well if your car didn't smoke that much why do you think it works? I'll tell you why. My father and I both use Lucas gas treatment regularly so this explains why we had so little smoke after the seafoam treatment. To me this shows that both products work really well because a seafoam treatment usually results in a "smoke show" and we didn't because our engines were pretty darn clean already.
We have both noticed a little more pickup and a smoother idle.
Bottom line is Seafoam and Lucas works so Use them.
First time Sea Foam user here. I had a P0430 check engine light on my 2004 LS 430 and it would intermittently go away but in the recent few days, it was on full time.
Did my research about sea-foam, seems complicated at first but once you read up enough and see that you can easily find the brake booster line, it was a piece of cake.
I put 1/2 can of seafoam in my gas tank( less than quarter tank gas) and the other half via the brake booster line. Waited for 10-15 minutes and it was a smoke show - revved the engine and also drove aggressively for about 5 - 10 minutes till the smoke subsided.
I reset the check engine light and it hasn't come back for 3 days now. Hopefully I wouldn't see it again. I added a second can of seafoam into the gas tank and filled it up full.The car feels so much smoother and quieter - certainly an improvement. My tank average hit 30 mpg on highway driving - something I've never seen before.
I plan to use it in the crankcase oil before my next oil change - hoping for better engine performance and better mpg. The seafoam website is also very useful and it clears a lot of myths - like the myth that says its not good for fuel pumps / filters and also to get precise usage instructions. http://www.seafoamsales.com/
Hope this helps
Philip John
www.usamagnum.com
Hope this helps
Philip John
www.usamagnum.com
