Knocking noise?
Hi there,
One more problem with my car (1998 UCF21 LS400). Just had the tie-rods replaced (both sides). Car is lowered on coilovers.
Problem is, and this only happens to the right front, is that when the car hits a pothole or a bump of some kind, it sounds likes the shock has bottomed out or something has hit against something else.. I can actually feel the chassis shake or hit something. My mechanic assures me it's nothing to do with bushings as he checked all, and tested the balljoints etc for play.
Funny thing is, I first thought the shock keeps bottoming out because of how low the car is, so I adjusted the shock to be much harder, but the noise is still present. In fact, the harder it is, the more frequent the noise. This means that the noise isn't actually the shock bottoming out, if I am not mistaken...
Any ideas?
Cheers
Any ideas?
Cheers
Check the sway bar bushing where it goes thru the frame on that side. If the bushing is gone it will bang like crazy on every bump in the road as the bar sticks thru a hole drilled in the frame rail.
Cheers mate.
Had a day-off today so brought the car to the mechanic again. Tracked it down to the coilovers bottoming out. Turns out the JIC coilovers has 2 ways of adjusting the ride height.. One to do with the spring and the other with the shocker itself.. (I struggle to understand it but that's what the mechanic told me) Mechanic said the shocker had very little travel, so he adjusted it, and now it doesn't bottom out unless it's a huge bump.. Still, I will bring the car back to adjust it for even longer travel. I hate the shake in the chassis when the shock bottoms out.
Yet, frankly, why the shock bottoms out more often when it is set to harder settings, is beyond me
Cheers mate.
Hectorm
Jul 29, 2007 07:10 AM
